I recent bought both the WWII 40 tooth and Chopmaster from Forrest. I was able to look at the WWII before having to leave from work, but have not been home yet to install them and put them to use.
My question is, what is the best way to remove the protective "plastic" off of the carbide and blade before using? Are there any other tips to pass along for the first time use of these blades?
I always thought it funny, they charge what they do, and no enclosed page to tell you how not to mess up your brand new blade. They do let you know several ways on their website how to get them sharpened, and fixed though.
I emailed them 2 weeks ago and all I got in return was to use WD-40 to wipe it down. I thought I worded my email better than that. I guess I'll just pick it off little by little. A guy a work with suggested just rip a board with it. LOL Maybe if it was a $20 blade.
Actually, sawing a board would work and not damage the blade(unless you own a SS) ...but it makes a mess. I've never had any problem peeling that stuff off unless they've changed what they use. Break it and pull it off in the direction the teeth are pointing.
I have several Forrest blades and have always just peeled the coating off the blade and then simply wipe off the oils. Then slap it on the saw and make some sawdust!
Hold the blade with a heavily gloved hand when removing the coating as the teeth are SHARP! Get an edge started and the rest will peel right off.
Enjoy your new blades, they are a pleasure to work with.
Same here, but just bought a Dimar 50 tooth combi blade that if anything like the 24 FTB one I have means no more Forrester blades I came wrapped in oil paper so just a quick wipe with M.S. and ready to use.
Just use your fingers and pull it off, wipe off the blade and get to work. Great choice, by the way. You will not be disappointed with a Forrest blade
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
