Question about using Azek in a project.
« back to Joinery forum
Forum topic by Robert posted 01-14-2020 03:46 PM 147 views 0 times favorited 4 replies Add to Favorites Watch
View Robert's profile
Robert
3602 posts in 2087 days
01-14-2020 03:46 PM
Hey guys, I’m thinking about making a waterpond out of Azek. I really love the Frank Klausz inspired one I made out of wood, but I let it run out of water and now it is leaking and won’t stop.
Rather than build another one of wood, I though about using Azek.
I’ve heard PVC cement will work and I’ve heard it will NOT work.
I’ve come across Christie’s vinyl glue anyone use that?
Seems the Azek cement is not too available around me.
Looking for an alternative waterproof glue.
View spitfirepete's profile
spitfirepete
10 posts in 347 days
#1 posted 01-14-2020 04:43 PM
Be care with long length…the stuff expands quite a bit with heat…..I had to replace an Azek top cap with wood on a cement wall due to stretch issues
-- I'm a consultant...when she wants my opinion, she will ask for it.
View OnhillWW's profile
OnhillWW
208 posts in 1839 days
#2 posted 01-14-2020 04:59 PM
Have you tried to dry yours out and seal inside joints with 100% silicone sealant?
I trimmed my garage with Azak and have played with it elsewhere. It does move a lot with the temperature but on such a small project I would not worry. I have used PVC cement with it and it works, best on cut edges and factory smooth with a slight roughing with 120 grit – avoid faux textured faces for glueing. Again if you develop a leak seal (inside seams) with silicone.
-- Cheap is expensive! - my Dad
View Bruizer's profile
Bruizer
10 posts in 1146 days
#3 posted 01-14-2020 06:16 PM
I just finished two window boxes made with Versatec. They recommend Weldon 705 PVC cement. It gives you 5 min. working time. I used Versatic biscuits and the 705 (no other fasteners). Plenty of time to work and very strong and waterproof when done. Easier than I thought it would be. Hope this helps
Bruizer
#4 posted 01-14-2020 06:17 PM
