Calculating board feet for a small panel (diagonals)
Forum topic by kyngfish posted 01-14-2020 12:05 AM 418 views 0 times favorited 9 replies Add to Favorites Watch
View kyngfish's profile
kyngfish
115 posts in 943 days
01-14-2020 12:05 AM
So I ran a search for this, and maybe I was using the wrong keywords, but I didn’t find anything. I can’t be the first person to ask this.
I need to make a 14”x14” panel, but i want to lay 2 inch wide boards diagonally. The hypotenuse of the two triangles in the door is more or less ~20” so I know I need 10 boards. But in the interest of not being wasteful with the wood, I’d like to know the best way to calculate the approximate amount of board feet I need in those 2 inch strips. Since they are going to be at a 45 degree angle, I am losing two corners off each board, so it has to be a little more than what it would be if I laid them perpendicularly.
9 replies so far
View LeeRoyMan's profile
LeeRoyMan
1419 posts in 581 days
#1 posted 01-14-2020 12:24 AM
-- I only know... what I know....
kyngfish
#2 posted 01-14-2020 12:30 AM
That’s awesome. Thank you. Just so I don’t feel like an idiot. How did you do that.
View AlaskaGuy's profile
AlaskaGuy
6007 posts in 3163 days
#3 posted 01-14-2020 12:30 AM
Draw it out full size on paper, cardboard or table top.
LeeRoyMan
#4 posted 01-14-2020 12:32 AM
That s awesome. Thank you. Just so I don t feel like an idiot. How did you do that.
- kyngfish
It’s Sketchup Drawing Program.
View Kazooman's profile
Kazooman
1540 posts in 2806 days
#5 posted 01-14-2020 12:42 AM
Calculations aside, whatever the final use for the panel, I would be much more concerned about examining the grain of the wood and trying for the best appearance, rather than trying to optimize the use of the stock. An ugly panel is an ugly panel even if it is the nuts on optimizing the use of the stock. Go for the calculations above, but allow a BIG allowance for the occasional not so pretty piece.
View LittleShaver's profile
LittleShaver
689 posts in 1474 days
#6 posted 01-14-2020 01:44 PM
I’m with Kazooman. Figure out how much you think you’ll need and then buy more. I like having extra around for mistakes and small projects, so I typically buy 15-20% over what I think I’ll need. If the price is good 25% over. I once stumbled into a good deal on slabs and bought one with no idea what it was going to be. It sat in the shop for a year or so until one day my wife looked it over and came up with a project for it.
Don’t over think it.
The only time I get as particular about stock quantity is when I’m trying to make something with what I have on hand. Then its more figuring out how much I can do with what I have.
-- Sawdust Maker
View Heyoka's profile
Heyoka
63 posts in 707 days
#7 posted 01-14-2020 03:01 PM
I doesn’t matter what orientation the panel is, it will be the same area so the board feet will be the same no matter if the boards are 90 or 45
-- Heyoka
View SMP's profile
SMP
2484 posts in 760 days
#8 posted 01-14-2020 03:13 PM
You also have to look at the width and length of the boards you are buying. For example, where I buy hardwoods, most planks come in 10-12ish feet. I am allowed to take a partial piece as long as I return 6’ to the racks. When you do stuff at diagonals you will waste a lot more than you think. I just did a herringbone plank wall and that burned even more. But I keep any scraps for other projects.
kyngfish
#9 posted 01-14-2020 04:33 PM
Appreciate all the feedback fellas.
@SMP and @LittleShaver I already have the wood, and the grain has been selected. I just wanted to draw it out on the rough cut lumber so I could be reasonably efficient.
@Heyoka – At 90 degrees I’m using a little over 8 bf, at 45 degrees, I’m using ~12 bf of 2 inch boards because you’re laying them at 45 degrees and cutting off the corners. So while in the end, the panel is the same amount of wood, it’s nearly 50% more bf.
