How would you guys sand this blistered live edge and still keep the look?
Forum topic by Jordan123 posted 01-13-2020 06:50 PM 812 views 0 times favorited 19 replies Add to Favorites Watch
View Jordan123's profile
Jordan123
60 posts in 709 days
01-13-2020 06:50 PM
I am starting work on this maple live edge table and want to keep the blistered look of the live edge
Im scared if it go at it with 80 grit to start on an orbital i’ll remove most of the blistering
19 replies so far
View Aj2's profile
Aj2
2650 posts in 2405 days
#1 posted 01-13-2020 06:59 PM
If you like the look of the edge then don’t sand it. Don’t do anything to it except lightly brush off dirt.
Good Luck
-- Aj
Jordan123
#2 posted 01-13-2020 07:06 PM
Good Luck
- Aj2
Its a little too rough at this point though. It needs some work done but I dont want to lose the blistering
View LesB's profile
LesB
2314 posts in 4050 days
#3 posted 01-13-2020 07:16 PM
You could try a fine wire brush, by hand or on a circular brush you can use on a drill. I’m thinking fine brass or similar. There are also circular sanding brushes that might work. Just search circular sanding brushes to find some.
-- Les B, Oregon
Jordan123
#4 posted 01-13-2020 07:18 PM
You could try a fine wire brush, by hand or on a circular brush you can use on a drill. I m thinking fine brass or similar. There are also circular sanding brushes that might work. Just search circular sanding brushes to find some.
- LesB
I was thinking about using a sanding mop chucked in a drill
View JackDuren's profile
JackDuren
720 posts in 1566 days
#5 posted 01-13-2020 07:22 PM
- LesB
Agree with the fine wire brush. You only remove what’s loose…
View SMP's profile
SMP
1596 posts in 512 days
#6 posted 01-13-2020 08:03 PM
I have a set of 3 wire brushes from harbor freight. A stiff plastic, a brass, and a steel . I start softest and slowly work up, stopping if i see it taking “too much” off. The “too much” is your eyes personal preference. On that personally i would go to the brass brush, not steel.
View Rich's profile
Rich
5141 posts in 1196 days
#7 posted 01-13-2020 08:29 PM
One of these will work. Pick your grit.
https://www.amazon.com/Dico-541-772-4-Nyalox-Wheel-4-Inch/dp/B00004YYD7
View Phil32's profile
Phil32
845 posts in 510 days
#8 posted 01-13-2020 08:34 PM
I don’t see any blistering on the edge. A live edge is typically the tree bark. Yours appears to be a rough split.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View LeeRoyMan's profile (online now)
LeeRoyMan
498 posts in 333 days
#9 posted 01-13-2020 08:59 PM
- Rich
I tried some of those Once!, Give me your address I will send them to you. lol
I didn’t like the ones I got.
View BurlyBob's profile
BurlyBob
6912 posts in 2872 days
#10 posted 01-13-2020 09:54 PM
I’d leave it as is. You touch with any sort of abrasive you stand the chance of losing all the character of that raw edge.
View Lazyman's profile
Lazyman
4513 posts in 1994 days
#11 posted 01-13-2020 10:03 PM
I don’t think that I would even use a wire brush. I would just use a stiff plastic bristle brush and only brush by hand.
I don t see any blistering on the edge. A live edge is typically the tree bark. Yours appears to be a rough split.
- Phil32
I think he’s talking about the little bumps that are indicative of the figure you can also see in the grain.
View Andybb's profile
Andybb
2376 posts in 1210 days
#12 posted 01-13-2020 11:16 PM
Pick your grit
But if you want the bumps I’d use a green scotchbrite pad and some sanding sealer.
-- Andy - Seattle USA
View pottz's profile
pottz
7696 posts in 1591 days
#13 posted 01-14-2020 12:45 AM
if you like that look leave it alone or just brush off any loose dirt at most.
JackDuren
#14 posted 01-14-2020 01:18 AM
- pottz
Agree…. you can’t finish lose bark…
View Kelly's profile
Kelly
2630 posts in 3551 days
#15 posted 01-14-2020 06:14 AM
Just run over it with 150, see what you think. If the sharp points are gone enough to make you happy, it’s a go. That’s what I did.
