Kreg ACS Dust Collection Adapter?
Forum topic by Brian Talbert posted 01-05-2020 12:50 AM 1410 views 0 times favorited 1 reply Add to Favorites Watch
View Brian Talbert's profile
Brian Talbert
38 posts in 1147 days
01-05-2020 12:50 AM
Anyone using the Kreg ACS plunge saw connected to your vac? What have you used to adapt the dust port to the hose?
-- www.instagram.com/w.brian.talbert/
1 reply so far
View Lazyman's profile
Lazyman
6970 posts in 2464 days
#1 posted 01-10-2020 11:59 AM
I don’t have that saw but you might check to see if the Rockler Flexi-port adapters might work. It is on sale right now. You might also have to purchase the expansion pack if one of the included adapters doesn’t fit. The fittings are a flexible rubber so that they can stretch a little or even fit a non round dust port in some cases. I would probably call them and ask them if they know whether one of their adapters fits.
The hose is a little on the heavy side IMO but it works for my odd sized sanders.
EDIT: I just looked at the manual. Below are the dimensions that I think you need to fit.
From the manual:
Dust Collection
(1) Align the large lug on dust bag with the large slot on the dust port, push on the dust bag and twist to lock. The 1.575” (40mm) outside diameter, 1.378” (35mm)
inside diameter dust port also accepts a
vacuum hose.
