dado blades
Forum topic by 3285jeff posted 12-28-2019 03:48 PM 468 views 0 times favorited 7 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
186 posts in 2499 days
12-28-2019 03:48 PM
I just bought a dado blade set and going by the directions for a 3/4 dado it said for me to use the inside and outside blade and 4 of the 1/8 chippers,,which I did and it does cut a 3/4 groove but its not as tight as I like it to be,,im really new at using the dado blades,,so if anyone can help me get a tighter fit I really would appreciate it,,thank you
7 replies so far
View GR8HUNTER's profile (online now)
GR8HUNTER
7591 posts in 1493 days
#1 posted 12-28-2019 03:52 PM
does your set have the 1/16 chipper ? :<))
View Oldschoolguy's profile
Oldschoolguy
108 posts in 617 days
#2 posted 12-28-2019 04:27 PM
Hey Jeff, Most dado sets that I know of should have a set of shims. Try leaving out a chipper and use the shims to match the dimensions of your cut. I’m relatively new to woodworking, so others may have more practical ideas. Hang in there. Future replies to your topic probably will help more than mine. Good luck with your project and keep me informed.
3285jeff
#3 posted 12-28-2019 04:29 PM
Yes it does have a 1/8 chipper
6258 posts in 3274 days
#4 posted 12-28-2019 04:34 PM
The answers above solve the problem. If you have the 1/16” chippir, install it in place of one of the 1/8” chippers, then use shims to get the width to where you want it.
3285jeff
#5 posted 12-28-2019 04:52 PM
Thank you..I will try that
View GaryCK's profile
GaryCK
93 posts in 830 days
#6 posted 12-28-2019 07:00 PM
I’ve also found that I need to test a dado cut every time I set one up, even if I’m using the same set of blades. I’ve not figured out why there would be subtle differences in dado width for a given combination of blades but there have been. I now always make a test cut in the same material before cutting a project piece.
-- Gary, Wisconsin
View WoodenDreams's profile
WoodenDreams
1076 posts in 692 days
#7 posted 12-28-2019 11:35 PM
If your inserting 3/4” plywood into the dado slot, it will fit very loose. 3/4” plywood is a little thinner than 3/4”. Just a reminder.
