Forum topic by steveinaz | posted 12-22-2019 09:16 PM | 416 views | 0 times favorited | 4 replies | ![]() |
I wanted to hook up a jobsite saw to my dust collector. I put a 4” to 2 1/4” reducer right on the dust collector. I ended up with a lot less suction. I’m guessing that there is some airflow dynamics reason for this, but I’m totall clueless. Is there a solution? Thanks in advance. -- Steve in AZ |
#1 posted 12-22-2019 09:25 PM |
You should not reduce at collector only at tool . You should have 4inch pipe at the tool and reduce to fit the too |
#2 posted 12-22-2019 10:24 PM |
I’ll give that a try. Thanks woodman71 -- Steve in AZ |
#3 posted 12-23-2019 03:04 AM |
4” dia is 12.5 sq in while 2-1/2” dia is just under 4 sq in or about 1/3 the raw area and over time, volume. Couple that with the higher resistance of the smaller hose and a significant loss of suction is to be expected. Remember too that the smaller diameter makes the system more prone to clogging. M -- The hump with the stump and the pump! |
#4 posted 12-24-2019 10:53 PM |
Also consider that air resistance increases with the cube of the air speed. So if air needs to move three times as fast to make up the same volume (e.g. CFM), it needs 27 times the force (suction) to move it (not likely gonna happen…), so you won’t get as much CFM through the smaller hose, especially if is it a significant portion of the total hose length. There is also a minimum air speed at which particles will stay suspended (depending on particle size and mass). So increasing duct diameter, past the point where the air speed drops below the carrying speed, is not a solution either. Generally, unless runs are very long, it does not pay to increase duct size past the size of the inlet to the extractor. As stated before, if you have to reduce the duct size to fit the tool (dust producer) then do so as near to the tool as possible. Andy -- Andy - Arlington TX |
Forum | Topics |
Woodworking Skill Share
13203 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1900 |
Finishing
6350 |
7913 |
32784 |
CNC Woodworking
330 |
Hand Tools
6456 |
Jigs & Fixtures
1808 |
Wood & Lumber
7284 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
