Forum topic by bbandu | posted 12-18-2019 03:05 AM | 1275 views | 0 times favorited | 4 replies | ![]() |
Topic tags/keywords: drill press craftsman CRAFTSMAN 13” Drill press Is $100 a good price for this. It shows some surface rust but works good. |
#1 posted 12-18-2019 06:20 PM |
What was original cost? Looks old which is good & bad. Old stuff is usually solid but needs to be cleaned, replace belt, check bearings etc. Motor may need rebuild/brushes. Offer 1/2 of asking but be willing to come up to 3/4. Caveat emptor! M -- The hump with the stump and the pump! |
#2 posted 12-18-2019 06:48 PM |
That drill press has a good throat depth and a solid stand and table. For me the only other thing to check (aside from bearings, motor etc) is the quill travel. For me, 2” of quill travel makes that a $50 drill press. 4” would get you my $100 though. I would also check to make sure that the table moves up and down as it should. Sometimes the pinion in the table or the rack will have busted or bent teeth which can be a huge PITA. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#3 posted 12-18-2019 07:00 PM |
I have an even older one… It’s still kicking from the early 70’s and is a beast. Also accurate. If it’s running well and looks in decent condition…... -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. |
#4 posted 12-20-2019 08:10 PM |
I have a 113.213850 and can think of nothing bad to say about it. If I ever need to drill a perfectly straight hole deeper than it can go, I’ll finish it with a handheld drill. There’ll be enough hole to force it straight. |
Forum | Topics |
Woodworking Skill Share
13543 |
Woodturning
3009 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6709 |
8187 |
34180 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5576 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
