Isopropyl + shellac
Forum topic by leftcoaster posted 12-15-2019 08:29 PM 1012 views 1 time favorited 23 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
374 posts in 1844 days
12-15-2019 08:29 PM
I found some 99% isopropyl alcohol at ACE. Any reason I shouldn’t use this for shellac?
Alternative is Kleen strip denatured.
Prefer fast drying.
23 replies so far
View AlaskaGuy's profile
AlaskaGuy
6338 posts in 3277 days
#1 posted 12-15-2019 08:37 PM
Isopropyl rubbing alcohol is no good for thinning shellac because it contains about 30% water. The water will cause the shellac to turn white, or “blush.” If you have access to 95-to-100 percent pure propanol or isopropyl alcohol, you could use it for thinning without a problem.
https://thefinishingstore.com/blogs/news/tip-shellac-thinner
View Kazooman's profile
Kazooman
1540 posts in 2920 days
#2 posted 12-15-2019 09:18 PM
Well, Alaska. He did say 99%.
OP. If you want fast drying you should go with ethanol.
View OnhillWW's profile
OnhillWW
289 posts in 2200 days
#3 posted 12-15-2019 09:55 PM
AG has it right. BTW – you will never find 100% ethanol. I worked in a lab and the purist possible is 99.9%; and, as soon as you open the bottle that drops because alcohol has such a strong affinity for water it pulls whatever there is in from the exposed air.
-- Cheap is expensive! - my Dad
Kazooman
#4 posted 12-15-2019 10:09 PM
Just picking a nit. While you can’t buy 100% ethanol in a can at the big box store, you can, with access to proper equipment and technique, prepare ethanol that is much drier than 99.9%. Very low parts per million residual water can be achieved. The comment about absorbing water on exposure to air are spot on. My favorite way to increase the water content of ethanol is to add a small splash of water to a good single malt whiskey.
AlaskaGuy
#5 posted 12-15-2019 10:57 PM
Just picking a nit. While you can t buy 100% ethanol in a can at the big box store, you can, with access to proper equipment and technique, prepare ethanol that is much drier than 99.9%. Very low parts per million residual water can be achieved. The comment about absorbing water on exposure to air are spot on. My favorite way to increase the water content of ethanol is to add a small splash of water to a good single malt whiskey.
- Kazooman
And I was just trying to help.
View Lazyman's profile
Lazyman
6304 posts in 2355 days
#6 posted 12-15-2019 11:32 PM
Does DNA also have the same tendency to absorb water from the air?
Shipwright (#24 here) said that he preferred using isopropyl in a thread asking for DNA alternatives since it is almost impossible to find in California (or Canada) these days.
View Ted78's profile
Ted78
415 posts in 2968 days
#7 posted 12-15-2019 11:32 PM
I don’t have a good answer for you, I’ve only ever seen 50, 70, and 90% Isopropyl. I doubt 99% would stay that way for long, it absorbs water from the air. BUT this is no different with ethanol, or methanol, all alcohols are hydrophilic ‘water loving’ so I suspect any type of alcohol above 90% or so would work just fine.
-- Ted
View shipwright's profile
shipwright
8638 posts in 3766 days
#8 posted 12-16-2019 01:00 AM
I just bought a gallon of 99%pure Isopropyl alcohol last week and yes it works great for dissolving and thinning shellac. If you prefer more brush marks by all means use DNA if you can buy it where you are but if you don’t, give isopropyl a try. You might never go back. It also works well for French polishing.
Lazyman
#9 posted 12-16-2019 03:09 AM
Sorry to go a little off topic but I often hear people say that as soon as you open a container of alcohol it will be contaminated with water from the air and it always makes me wonder. I don’t doubt that alcohol will absorb some water from the air, It just seems like an extreme statement that is often repeated and I have never heard anyone provide any facts about the phenomenon. I hear similar statements about alcohol/water in gasoline, though that may just be conspiracy theorists. I would think that if you keep your alcohol container closed except when pouring some out, water absorption should be negligible.
Doing the math:
  • At 100% RH at 25° C (~77F), 1 cubic meter of air contains about 20 gram of water.
  • A 1 gallon can is about 0.003785 cubic meters (264 gallons/m3)
  • 1 gallon of air would contain about 0.0757 grams of water at 100%/24°C
  • 1 gallon of Isopropyl alcohol weighs about 2721 grams.
So, unless I screwed up the calculation, in order to raise the water content 1% by weight (27 grams), 1 gallon of alcohol would have to absorb all of the water from 1.36 cubic meters or about 360 gallons of the air.
Perhaps I am missing something.
View smallerstick's profile
smallerstick
31 posts in 2145 days
#10 posted 12-16-2019 12:36 PM
Find a marine supply store and get some stove fuel. That is usually denatured alcohol (ethanol) and is relatively inexpensive.
-- Peter
6726 posts in 3461 days
#11 posted 12-16-2019 01:25 PM
- Lazyman
There’s always someone trying to screw up a good myth with solid facts! :)
View Dark_Lightning's profile
Dark_Lightning
4314 posts in 4077 days
#12 posted 12-17-2019 01:39 AM
Any alcohol will mix with water. If one uses a closed container and pours out what is needed and then closes the container, it will be a long while before the alcohol is significantly “contaminated” by water. Not having seen the discussion about isopropyl alcohol, where can one buy that at a decent price? We used it at work to clean spacecraft parts, but I don’t need it that pure. Reviewing the thread, I’ll look at ACE for some isopropyl alcohol. I will also note that denatured alcohol isn’t just ethanol. It has a bitterant added to keep people from drinking it. If it was pure ethanol, it would require a tax stamp. We used that for cleaning the lenses of spacecraft optics, and a five-gallon can (with a tax stamp) seemed to evaporate much quicker than one would expect. Heh heh heh. Wasn’t me, though. I like to keep my wits about me around that kind of expensive hardware.
-- Steven.......Random Orbital Nailer
shipwright
#13 posted 12-17-2019 05:54 AM
Steven, I get mine at a feed store. They sell it as horse liniment but it’s 99%pure isopropanol.
View CaptainKlutz's profile
CaptainKlutz
3987 posts in 2462 days
#14 posted 12-17-2019 06:54 AM
+1 Isopropyl Alcohol 99% works
Feed store Isopropyl Alcohol is usually cheaper than hardware store too.
Try looking for a Farm & Fleet, or Tractor Supply Corp (TSC).
+1 Another source for denatured ethanol alcohol is ‘stove fuel’.
Sold at camping and marine stores.
From another thread on this is topic; if you use DNA, use the GREEN label version from Keenstrip, not the red label. It has less methanol alcohol and dries with less streaking when brush shellac.
OnhillWW
#15 posted 12-17-2019 02:26 PM
I never said that water absorption would be such that it would alter the product enough to matter – my point was that it is not sold in a100% formulation because it is so hydrophilic and if it is stated to be 100% it is false advertising. Whether 99.9% or 99% or 90%, it will not make any real world difference to us when thinning finish.
Ethanol fumes are less harmful (less harmful) than isopropyl so I always go that route – it’s your liver treat it to whatever you want.
