Automated jointers, why aren’t there any?
Forum topic by Sark posted 12-15-2019 03:30 AM 2145 views 0 times favorited 46 replies Add to Favorites Watch
View Sark's profile
Sark
419 posts in 1522 days
12-15-2019 03:30 AM
Topic tags/keywords: jointer jointing
OK, I’m lazy, but what I want is to feed the wood in one end and have jointed wood come out the other. Maybe will take two or three passes. But no skill required. And no handwork. It just doesn’t seem that hard too me to have a tool that grabs the wood like a planer does and runs it over a jointer. What am I missing?
Big woodworking operations must have automated jointers. But has no one figured out to make a small shop version?
46 replies so far
View avsmusic1's profile
avsmusic1
682 posts in 1847 days
#1 posted 12-15-2019 03:37 AM
I suppose you could use a feeder
View bigblockyeti's profile
bigblockyeti
7451 posts in 2883 days
#2 posted 12-15-2019 03:37 AM
This is close but I can’t attest to the surface finish which based on what can be achieved with other track saws it’s probably pretty good.
https://www.thesawcentre.co.uk/power-tools-c97/circular-saws-systems-c154/mafell-automatic-panel-saw-with-pre-scoring-pss3100-se-p1518
View pottz's profile (online now)
pottz
18825 posts in 2146 days
#3 posted 12-15-2019 04:14 AM
sure no problem,how much money are you willing to spend.you running a commercial operation and time is money? comon,enjoy the process,or are you doing it for a living? if your that lazy get a new hobby-geezz!!!!
View AlaskaGuy's profile
AlaskaGuy
6699 posts in 3471 days
#4 posted 12-15-2019 05:24 AM
This is close but I can t attest to the surface finish which based on what can be achieved with other track saws it s probably pretty good.
- bigblockyeti
How do you joint the face of a board with a track saw?
AlaskaGuy
#5 posted 12-15-2019 06:06 AM
- Sark
No one figured out how to make one priced for the Harbor Freight woodworker.
View Sylvain's profile
Sylvain
1312 posts in 3662 days
#6 posted 12-15-2019 09:37 AM
Matthias Wendel has made a home-made one:
https://woodgears.ca/machinery/power_feeder.html
I am hand planing, but if I understand correctly, on a jointer, one has to press the (planed) board firmly against the fence AND a bit down simultaneously.
Obviously you are not a fan of Paul Sellers
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View Nubsnstubs's profile
Nubsnstubs
1792 posts in 2892 days
#7 posted 12-15-2019 12:26 PM
The idea of using a jointer to flatten one side of the stock is to start it and immediately apply pressure on the outfeed table. That will allow the jointer to do what it was designed to do. Using a power feeder over the knives would do nothing more that cut the surface, not aid in removing twists that some woods have. ......... Jerry (in Tucson)
View Underdog's profile
Underdog
1688 posts in 3198 days
#8 posted 12-15-2019 01:16 PM
Yes they make that kind of a thing.
It’s called a molder. Properly set up it will straighten out wood to a degree. Better molders have an adjustable infeed table and fence to ensure 4 side surfacing. However, if the stock is long enough the feed wheel pressure (hold down pressure) will straighten it out instead of jointing it, and it will spring back once it’s out the other end.
-- Jim, Georgia, USA
View TungOil's profile
TungOil
1384 posts in 1657 days
#9 posted 12-15-2019 01:20 PM
It has been available for years, it’s called a stock feeder. Here’s an excerpt from the Powermatic manual for my feeder (which is mounted on my shaper). It then tricky to mount one to a jointer, but I’m sure it can be done.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View ohtimberwolf's profile
ohtimberwolf
1100 posts in 3514 days
#10 posted 12-15-2019 01:20 PM
For who wants to see it… Here is a video of Bigblock’s link in action. I have never heard of one let alone seen one working. larry
https://www.youtube.com/watch?v=Tn8npDkfKCo
-- Just a barn cat, now gone to cat heaven.
bigblockyeti
#11 posted 12-15-2019 02:11 PM
- AlaskaGuy
It would be better suited for edge jointing in a single pass or you could face joint with A LOT of passes.
View Jack Lewis's profile
Jack Lewis
576 posts in 2240 days
#12 posted 12-15-2019 02:17 PM
How can a woodworker say “I am a wood worker” if he doesn’t want to work with wood? It would just be another HO HUM job.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View Jared_S's profile
Jared_S
466 posts in 1121 days
#13 posted 12-15-2019 02:37 PM
They do make them. They are called facers.
Alternatively most shops run them for a s4s moulder and skip jointing and planing.
Poor mans version a feeder on the outfeed side of the jointer.
View JackDuren's profile
JackDuren
1633 posts in 2122 days
#14 posted 12-15-2019 02:46 PM
The last one I looked at for Jacobe furniture was $45,000. They make them cheaper but this one was for running 3 shifts.
View Sark's profile
Sark
#15 posted 12-15-2019 03:29 PM
Jared, thanks for pic of the facer. That’s what I was thinking but for about $2,500. Now the guy feeding that monster all day long looks like he’s having a blast. A real woodworker, I’d say.
Stock-feeder mounted on jointer, that seems so simple, and relatively inexpensive, that I’m surprised that I just can’t go buy one at Rockler. Except I don’t want some jury rigged system. I want a machine designed for auto-jointing. How about one of those combo planer-jointer machines modified so that one-half planes and the other joints, all using the same cutters and stock feed mechanism. Is that so hard to imagine? I’ve got my credit card handy.
PS, there are a number of stock-feeder-on-a-jointer videos on Youtube. Why no home shop version? Is it lack of imagination on behalf of the tool builders? Or is there some inherent design challenges that make it completely impractical to produce at low cost?
showing 1 through 15 of 46 replies
