Work bench finish
Forum topic by woodetal posted 12-14-2019 06:04 PM 382 views 1 time favorited 16 replies Add to Favorites Watch
View woodetal's profile
woodetal
35 posts in 379 days
12-14-2019 06:04 PM
I just sanded down my
bench, 7” of oak on the edge and pine for the rest of the top. It is a multi task bench, not dedicated to furniture making. What finishes have you used?
16 replies so far
5928 posts in 3100 days
#1 posted 12-14-2019 07:34 PM
The only one I’ve used is a mixture of beeswax, BLO, and turpentine (or MS, either one). Let the wax dissolve in the MS, mix it up and add BLO. It does take a day or 2 to dry but never flakes or chips, is easily renewable, and does offer some moisture resistance. It you drip a little glue on it, it pops right off.
View pottz's profile
pottz
7696 posts in 1591 days
#2 posted 12-14-2019 09:04 PM
ive always just waxed mine considering the abuse it gets i can just apply more wax as needed.
View JayT's profile
JayT
6358 posts in 2818 days
#3 posted 12-14-2019 09:09 PM
I just use a coat or two of Watco Danish oil. Simple to use and it offers a bit of protection and color without making the bench slick.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View Axis39's profile
Axis39
145 posts in 204 days
#4 posted 12-14-2019 09:22 PM
- pottz
Bowling Alley Wax is one of my favorites.
A lot of the time I just throw whatever bottle of old finish is on the shelf, if I do anything at all. Could be shellac, could be polyurethane, could be BLO…. But, it almost always gets wax on top.
-- John F. SoCal transplant, chewer uppper of good wood
pottz
#5 posted 12-14-2019 11:55 PM
- pottz
- Axis39
ok i just heard of a new one, bowling ally wax,whats different?
View Mr_Pink's profile
Mr_Pink
184 posts in 978 days
#6 posted 12-15-2019 03:52 AM
I don’t have a finish on my workbench top, and I never think about adding one.
View Mosquito's profile
Mosquito
10002 posts in 2899 days
#7 posted 12-15-2019 03:56 AM
I too skip the finish on my bench
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View GrantA's profile
GrantA
2128 posts in 2014 days
#8 posted 12-15-2019 04:07 AM
My bench is old butcher block countertop, after sanding the funk off them I used danish oil and paste wax
View MrWolfe's profile
MrWolfe
616 posts in 730 days
#9 posted 12-15-2019 04:21 AM
i like Fred Hargis’s finish. I played around with one that is similar.
Here is the link to a recipe I came up with for benches.
I love it. Easy to apply and maintain. Just tacky enough for a bench but a beautiful finish.
https://www.lumberjocks.com/replies/5230001
Good luck with your bench!
Jon
pottz
#10 posted 12-15-2019 04:26 AM
- GrantA
- GrantA
now that’s a patina,a mans bench top tells his storey.
Axis39
#11 posted 12-15-2019 05:20 AM
- pottz
It’s bowling alley wax…. At least that’s what it was originally decveloped for. I used to use Johnson brand, but Home Depot stopped carrying it. So, now I use: Butcher's. I buy it in a smaller container at Home Depot (or at least I did last time I needed some… I can’t find it online there now.)
View SMP's profile
SMP
1596 posts in 512 days
#12 posted 12-15-2019 05:29 AM
I followed Richard Maguire’s advice of mixing 50/50 BLO and terps, and applying enough coats where no more will soak in(5 or 6 in my case). Has a nice grippy texture that helps keep your work from flying around like a waxed bench, but glue drips still pop off.
View Lazyman's profile
Lazyman
4513 posts in 1994 days
#13 posted 12-15-2019 01:32 PM
For those of you who just use wax, I assume you are using a paste wax? Is it a PITA dealing with it collecting in the little divots that result over time from use? I would be concerned that any divots that retain a glob of wax I miss when buffing it might deposit it on something I’m working on and affect finishes?
View fuigb's profile
fuigb
568 posts in 3564 days
#14 posted 12-15-2019 01:49 PM
Wipe-on poly, maybe 10 or 15 coats. It is so easier to clean off the spills and glue that come with ordinary use.
-- - Crud. Go tell your mother that I need a Band-aid.
View LittleShaver's profile
LittleShaver
609 posts in 1226 days
#15 posted 12-15-2019 02:51 PM
Shellac. Easy to apply, easy to renew, glue pops off, and a great way to use up extra.
-- Sawdust Maker
