Enlarging screw hole in some Sorby Cutters
« back to Woodturning forum
Forum topic by Jack Lewis posted 12-14-2019 02:23 PM 307 views 0 times favorited 4 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
571 posts in 1684 days
12-14-2019 02:23 PM
Some of the Sorby HSS and Carbide cutters do not fit the gooseneck hollowing bar I want to use. What method is used to enlarge these mounting holes? Will a regular drill ream the hole?
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View TheDane's profile
TheDane
5727 posts in 4268 days
#1 posted 12-14-2019 02:32 PM
Just a WAG, but I think you’ll need a carbide bit. I have never had any luck trying to drill HSS with an HSS drill bit.
View Nubsnstubs's profile
Nubsnstubs
1660 posts in 2335 days
#2 posted 12-14-2019 03:46 PM
Just a WAG, but I think you ll need a carbide bit. I have never had any luck trying to drill HSS with an HSS drill bit.
- TheDane
Jack, Gerry’s right. Carbide drill bit….... Only way to drill through HSS….......... Jerry (in Tucson)
View Lazyman's profile
Lazyman
4502 posts in 1993 days
#3 posted 12-15-2019 02:33 PM
How much larger do you need to make them? If it is just a smidge, how about a dremel with a cone shaped grinding stone bit. You could also chuck the stone in a drill press for a little more control. For a carbide cutter, you would have to use a diamond one. If you have to enlarge the countersink, that could be another issue.
Jack Lewis
#4 posted 12-22-2019 02:57 PM
- Lazyman
There is the answer I was looking for. Thank you. I had forgotten the Dremel diamongs.
