Use leftover raw wood countertop for cutting boards?
Forum topic by AM420 posted 12-13-2019 09:26 PM 2741 views 0 times favorited 60 replies Add to Favorites Watch
View AM420's profile
AM420
335 posts in 1546 days
12-13-2019 09:26 PM
I recently renovated my kitchen and in the process decided to go with solid wood countertops because they were a lot cheaper than most alternatives: about $300-$500 each Depending on length from Floor and Decor the wood is American Cherry.
I have a large section leftover and thought maybe I could just cut it up and turn into some end grain cutting boards for Christmas gifts! Any reason to think this wouldn’t be a good idea due to wood type, source/manufacturing, or anything else?
Thanks
60 replies so far
View AlaskaGuy's profile
AlaskaGuy
6699 posts in 3471 days
#1 posted 12-13-2019 09:36 PM
Sure you can. While cherry isn’t the hardest wood it is a closed grain wood.
Woods like hard rock maple, walnut, cherry (all materials used by John Boos), and teak are considered “close grain,” meaning they have small pores for a smoother surface less friendly to bacteria.
AM420
#2 posted 12-14-2019 12:50 AM
Thanks. Now I’m trying to decide to cut strips and make it end grain or leave it edge grain. A 2 month old gurl limits my shop time a lot, but end grain would probably be best with a softer wood.
View Axis39's profile
Axis39
522 posts in 759 days
#3 posted 12-14-2019 01:42 AM
End grain is best for any wood for a cutting board.
Think about how a blade interacts with grain. Edge grain, and it either slips between, or slices the grain. End grain, it almost always slips between.
-- John F. SoCal transplant, chewer uppper of good wood
View AZWoody's profile
AZWoody
1478 posts in 2386 days
#4 posted 12-14-2019 01:55 AM
The only thing I would take pause is over what glue is used.
It’s possible it’s a urea formaldehyde glue if the countertops are finished with a varnish.
If the countertops are wood only that need wax, then it should be fine.
View pottz's profile
pottz
18825 posts in 2146 days
#5 posted 12-14-2019 02:37 AM
youll be fine people worry too much about the finish or whatever,if it’s cured and dry it’s fine.you might wont to test for lead paint and asbestos though just to be safe!. ;)
yeah im a smart ass.
AlaskaGuy
#6 posted 12-14-2019 03:01 AM
If he’s going to end grain it he’ll have to remove the finish so he can glue the pieces together. I wish he’d post if it’s finished or not. A picture would be really helpful also.
pottz
#7 posted 12-14-2019 03:06 AM
If he s going to end grain it he ll have to remove the finish so he can glue the pieces together. I wish he d post if it s finished or not. A picture would be really helpful also.
- AlaskaGuy
true if he’s gonna slice off pieces and glue together.hopefully he will come back,so many dont?
View Aj2's profile
Aj2
3952 posts in 2960 days
#8 posted 12-14-2019 03:19 AM
I’d be interested to see if you can make a cutting board out of a scraps. Ive messed with cuts off from pre fab counter tops and found them to have lots of stress.
I think when they make them they clamp the crap out of whatever wood come out of their s4s moulder. Straight or not it goes into the clamps.
Hopefully your product was better then what I had.
Good Luck
-- Aj
AZWoody
#9 posted 12-14-2019 03:47 AM
My problem isn’t with the finish, it’s with the possible use of urea formaldehyde glue which is used in a lot of large scale manufactured goods like that as well as plywoods.
AM420
#10 posted 12-14-2019 04:06 AM
It was unfinished so no worries there. I was concerned with adhesive or anything other treatments. I may have to try to get the manufacturer on the phone to check for sure. I’m sure they’ll be like pulling teeth.
View becikeja's profile
becikeja
1175 posts in 3975 days
#11 posted 12-14-2019 12:52 PM
The heck with the cutting boards, I want to see a picture of the Cherry counter tops
View Lazyman's profile
Lazyman
7436 posts in 2550 days
#12 posted 12-14-2019 01:21 PM
- becikeja
+1
AM420
#13 posted 12-14-2019 04:02 PM
Nothing too special I think, and there’s still work to do to finish the kitchen, but here’s a couple of photos.
pottz
#14 posted 12-14-2019 07:18 PM
love wood counters i wish i could convince the wife.
AlaskaGuy
#15 posted 12-14-2019 09:20 PM
I guess you plan on never letting any food touch your kitchen counter tops.
showing 1 through 15 of 60 replies
