LCD TV "Tie-Down"
Forum topic by jdmaher posted 12-12-2019 11:04 PM 352 views 0 times favorited 9 replies Add to Favorites Watch
View jdmaher's profile
jdmaher
463 posts in 3188 days
12-12-2019 11:04 PM
Just got father-in-law a new 55” LCD TV. Setting it on an console / TV cabinet that’s plenty big for it.
TV only weighs 17 lbs. and it sits on these flimsy plastic feet. The cabinet is sturdy enough (though just veneered press-board). As I watch him tooling around in the wheelchair, I worry that he’ll knock in to the cabinet and cause that plastic TV to tip right over.
Can’t mount the thing to the wall ‘cause this is a brand new assisted living center and NOTHING can get screwed to the walls (silly, but no use fighting city hall).
My first reaction is to lay some pierced metal strapping over the feet and cinch ‘em down with some wood screws. Four such “anchors” should ensure no tipping, and there’s no way he can knock over the whole cabinet.
Anybody got a better idea?
-- Jim Maher, Illinois
9 replies so far
View sras's profile
sras
5289 posts in 3738 days
#1 posted 12-12-2019 11:10 PM
You could make some wood hold downs. A set of 4 that reach over the edge of the feet and screw into the cabinet. Finish to match the cabinet. Hope that makes sense…
View BlasterStumps's profile
BlasterStumps
1497 posts in 1048 days
#2 posted 12-12-2019 11:15 PM
How about attaching straps to the TV and then to the upper back edge of the cabinet? At least then it can’t fall forward. That is what I did in a similar situation. I think I just bought a kit for that very purpose.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View AlaskaGuy's profile
AlaskaGuy
5522 posts in 2917 days
#3 posted 12-12-2019 11:30 PM
No much help here but can’t help from saying “if you have ever been a landlord you’d better understan why they don’t what people screwing thing to the wall”.
View torus's profile
torus
386 posts in 1021 days
#4 posted 12-12-2019 11:37 PM
plywood piece size of the cabinet top and your options are unlimited (epoxy, screws, etc)
-- "It's getting better..." - put this on my RIP stone!
Craftsman on the lake
3099 posts in 4046 days
#5 posted 12-12-2019 11:37 PM
How about attaching straps to the TV and then to the upper back edge of the cabinet? At least then it can t fall forward. That is what I did in a similar situation. I think I just bought a kit for that very purpose.
- BlasterStumps
That would be my solution so I ditto this idea.
View Ripper70's profile
Ripper70
1371 posts in 1517 days
#6 posted 12-13-2019 05:41 AM
There are several simple solutions available that might suit your situation…
QuakeHOLD! 4520 Universal Flat Screen Safety Straps
Non Tipping Safety Strap Kit
I personally prefer the store bought method over the metal straps with the wood screws. Cleaner, relatively inexpensive and designed to do what you’d want it to do.
You could also opt for a more sturdy stand to replace the flimsy plastic feet with something like this.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View therealSteveN's profile
therealSteveN
4655 posts in 1182 days
#7 posted 12-13-2019 05:47 AM
Or use any of the Goop, Sticky strip kinda of stuff. It will hold a TV to a wall, so it would certainly keep one from tipping over off of a cabinet. Evidently all the earthquake prone folks of Cali use it to hold their valuables still during a quake.
-- Think safe, be safe
View CaptainKlutz's profile
CaptainKlutz
2257 posts in 2103 days
#8 posted 12-13-2019 07:40 AM
Two more suggestions, both utilization the VESA mount on back of TV:
1) Install a piece of plywood on back of cabinet, and either mount the TV directly to it, or use wall mounting kit.
2) If back of cabinet is junk, then make a “L” shaped bracket; one side under the TV, and one behind. Screw the plate under the TV to top of cabinet. Mount the TV like the #1.
With both of these, the entire cabinet will fall forward, if it’s going to fall.
The VESA mount uses metric screw size based on the size of the TV mounting plate. Can find the VESA standards information online easily.
Cheers!
View Woodknack's profile (online now)
Woodknack
13019 posts in 2988 days
#9 posted 12-13-2019 07:58 AM
I would either screw through the tv base into the stand or use carpet tape.
