Hi, i am working on a spoon and can't hold it well for a certain area. The area about in the middle of the side the spoon where you have to carve back towards the handle. When carving this area the only way I can hold it is by the tip of the spoon and not to well are there other ways. I don't have a shave horse and won't have
I have a wooden bench/table with just a few 3/4 inch holes in it. I use a Dewalt 24 inch clamp that I can remove the head from, insert the clamp through the hole from the bottom, and then reattach the head from the top. I have used this to do some recent carving because I don't have a shavehorse yet either.
I have made different "jaws" from scrapwood to fit the shape of what I am carving. I've also used old rags or rolled up cardboard as a block to better fit the piece I am working on.
I sometime use a small wooden block on the bottom jaw to give me extra clearance when tightening or releasing the clamp.
It works surprisingly well for me. I have sometimes built a jig that will support the piece THEN used the clamp to hold both pieces down.
Jon
In the future you can leave extra wood and use that to screw the spoon down with… then cut off that tab later after it is shaped.
I have used the Paul Sellers clamp in a vise method with a HF sash clamp, as well as a wood screw clamp to grab the spoon blank and clamped that to my bench as well.
I can't find the one I always wanted to make, but it was simply a flat piece of wood that sat on your lap. it had holes drilled for a sting looped through that you could keep pressure with your feet.
Funny this is posted today I was reading a blog by LJ Mafe yesterday and saw this picture. I thought it was so brilliant that I saved it. You could easily adapt it to a board that you lay on your lap like Don suggested by strapping the back end around your thigh to prevent it moving.
If you are hand-holding the spoon, just hold it by the handle. If you are carving with a lapboard to work bench, use an F-clamp to clamp the handle to the board/bench with the spoon bowl projecting over the board/bench into the air.
It is often necessary to plan ahead for how you will hold a carving for future steps. Sometimes it is helpful to leave part of the wood blank uncarved to allow for clamping. On a spoon, for example, it is a good idea to leave the back of the spoon bowl flat until after the inside of the bowl is done.
thanks for youre suggestion on the shave horse good ideas. I found this one on pinterest, it clamps to a bench, smaller and more portable. shave horse
Claude i can't hold by handle because on one side I will be cutting in the wrong direction and the wood will split instead of cut
Some cool ideas here. One of my projects going on now is a Schwarz saw bench. I was thinking of integrating a clamp on horse like the one above that i could attach/remove as needed onto this saw bench. I'll have to draw up some designs off these.
that is a cleaver tool, I can see its value for do the bowl but not for the outside. The work is so low that a straight knife will not be able to cut any direction except down
First I have to say, I got the inspiration from this video by Jarrod Dahl:
I just wanted to avoid a big footprint of a real spoon mule or a shaving horse, so I adapted it to a workbench attachement. It is really easy to build. The bottom board is glued together from two leftovers of a kitchen counter top. I chiseled in a hole vertically with a slight angle on the side walls. Then I drilled two holes into the sides for the wire which holds the pedals/clamping jaws (just two long sticks) and acts as a hinge. That's it. Much better to see in Jarrods video than getting from my stumbeling words.
But feel free to ask anything. It will be a pleasure for me to help if I can.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
