Forum topic by MiniMe | posted 12-10-2019 05:40 PM | 2855 views | 1 time favorited | 38 replies | ![]() |
Hi guys I am looking for design options for a table that will serve as permanent stand for a miter saw (in the middle) , drill press and a 9” band saw (if I ever get to buy one) I came up with two designs:
What problems do you foresee with each one of them and which one do you favour? |
38 replies so far
#1 posted 12-10-2019 05:55 PM |
I made something similar but with a different elevation changing set up. Attached are a couple of Sketchup renditions and a cut away line drawing. It works well and I have used it for 10 years but is a little cumbersome to change the height, requiring me to work around the bench changing the elevation in small increments. If I had a second person it would be easier. I have always thought I should add a scissors jack or some sort of hydraulics. Also while I left the lower part open you could add doors or drawers. I did put shelves in the end between the supports. -- Les B, Oregon |
#2 posted 12-10-2019 05:57 PM |
Looks like a lot of adjustments. I don’t know how much travel you need but you could allow the top to move up on posts and have a milled block to act as a spacer to get to table saw height. |
#3 posted 12-10-2019 06:21 PM |
I considered that as well but the issue is that I have an uneven floor and the table saw and the workbench might not necessarily land in the same position every time -hence the need to adjust every time. I can use what you said as a quick setup and see if it works, the designs do not exclude that option |
#4 posted 12-10-2019 06:26 PM |
Nice design but I want to keep it simple and my router is not in place yet I think that the all thread rod design is safer but the other design could be used as a bench wise if you take the table top out :-) |
#5 posted 12-10-2019 06:40 PM |
Wondering if you could use hinges on the tops of the posts to allow full height adjustment on one side and then the other without having to do incremental adjustments going around the table. |
#6 posted 12-10-2019 07:17 PM |
have to be heavy duty the other thing is that you lose the option to use the vise in the first design |
#7 posted 12-10-2019 11:15 PM |
You might want to look at the plans for a Jack-bench, https://www.jack-bench.com/ he has been around for a while. I am still thinking I might build one, just have not gotten around to it yet. Dan |
#8 posted 12-10-2019 11:36 PM |
That is definitely a nice idea but it will take from the under the table space. If I find two cheap auto jacks I could attach them at each side, on the exterior ! Good point, thank you |
#9 posted 12-11-2019 07:01 PM |
So, this discussion spurred me into looking at some sort of jack system and I found scissor jacks from the basic automotive types for around $25 (some had mounting flanges on the top) to motorcycle jacks with larger platforms in the $60+ range. You might even find old car scissor jacks at the wrecking yard even cheaper. I think I will add one of these to the bench design I posted above. That way I can release the 4 corner clamps adjust the height with the jack and re-clamp it. If the floor was uneven minor adjustments could be made by hand to level the top. -- Les B, Oregon |
#10 posted 12-11-2019 08:58 PM |
I have always liked this one: https://www.youtube.com/watch?v=IBX-AtmSFJA -- A bad day woodworking is still better than a good day working. |
#11 posted 12-11-2019 10:09 PM |
I recycled a car not very long ago. I do not remember what I did with the jack :-( (I have had a very stressful couple of months this year) |
#12 posted 12-11-2019 10:21 PM |
You could buy this and the problem is solved https://www.ikea.com/ca/en/p/linnmon-finnvard-table-white-s09001986/ And here is the crank version https://www.ikea.com/ca/en/p/skarsta-underframe-sit-stand-f-table-top-white-20288736/ |
#13 posted 12-12-2019 01:58 AM |
You could start with HD’s adjustable bench frame. It has a 300# capacity: You can go for something with more capacity: Norden is an option: Good luck, -- Doug - As my Dad taught me, you're not a cabinet maker until you can hide your mistakes. |
#14 posted 12-12-2019 04:11 AM |
The HD seems model seems to be a nice option I need to crunch the numbers to see if I want to buid it myself or buy that one. I am afraid that the size that I need is going to cost more than if I build it from 2×4 BTW, would you advise straightening the 2×4s using the table saw? |
#15 posted 12-12-2019 08:55 AM |
If you don’t need all the different height ranges in between, but just two different heights, I would think about a second top with some spacer blocks in between. That way, you could have the lower needed height with the two tops laying on each other and the second height buy putting the blocks in between. -- Uwe from Germany. |
Forum | Topics |
Woodworking Skill Share
13240 |
Woodturning
2830 |
Woodcarving
578 |
Scrollsawing
417 |
Joinery
1913 |
Finishing
6396 |
7940 |
32939 |
CNC Woodworking
334 |
Hand Tools
6487 |
Jigs & Fixtures
1825 |
Wood & Lumber
7309 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5436 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
