router bit for small boxes
« back to Joinery forum
Forum topic by birdman1charlie posted 12-09-2019 07:32 PM 323 views 0 times favorited 13 replies Add to Favorites Watch
View birdman1charlie's profile
birdman1charlie
20 posts in 780 days
12-09-2019 07:32 PM
I have a question about finger joint router bits. I want to do some small boxes with ¼ inch thick sides and 1½ to 3 or 4 inch high. I have done drawers ¾ in thick and used a finger joint jig but for this thin of sides I think the all in one type of bit would make doing the corners much quicker and easier.
I have searched the forums but the discussions move into making jigs.
CMT makes a bit- model 800.616.11 that does 5/32 fingers. I think that would do what I want.
Good idea? Bad Idea? Are you nuts idea?
Thanks for you for your thoughts and Merry Christmas.
Charlie
13 replies so far
View therealSteveN's profile
therealSteveN
4655 posts in 1183 days
#1 posted 12-09-2019 10:06 PM
Oooops a double tap
-- Think safe, be safe
therealSteveN
#2 posted 12-09-2019 10:07 PM
For many years Shaker seed boxes have been made using small finger joints on boxes 3 to 5” tall. Provides a LOT of glue area, and makes an incredibly strong corner. The downside is it also tends to chew up some wood, softwood would be really poor here with a lot of breakout, think harder woods, and straight grain. Plus you’ll get more mileage with 3/8” thick stock, still thinner than normal, but not friable.
- therealSteveN
View Aj2's profile
Aj2
2651 posts in 2406 days
#3 posted 12-10-2019 12:58 AM
5/32 is such a small bit I would have trouble making a jig to work. I’ve tried with 1/4 router bits and it was difficult for me.
A table saw is the way to go with rip blade.
5/32 router bits are not very expensive. Why not give it a try.
Good Luck
-- Aj
View Madmark2's profile
Madmark2
722 posts in 1197 days
#4 posted 12-10-2019 01:28 AM
I think he’s thinking of this type of cutter.
This cutter limits the max stock to the height of the cutter. Cutting both sides is problematic.
Production box joints have a stack of blades and spacers on a common shaft to cut all the fingers at once.
This is the type of operation where thousandths matter in the stock width & thickness.
-- The hump with the stump and the pump!
View Aj2's profile
Aj2
#5 posted 12-10-2019 01:42 AM
Thanks mark for clarifying for me.
That bit looks like $$$ probably not worth experimenting with.
-- Aj
Madmark2
#6 posted 12-10-2019 01:51 AM
$50 at mlcswoodworking.com
View Davevand's profile
Davevand
151 posts in 1445 days
#7 posted 12-10-2019 03:34 AM
I think a router bit would be difficult with thin stock. I would use a Table saw using a thin kerf blade
View Andybb's profile (online now)
Andybb
2387 posts in 1212 days
#8 posted 12-10-2019 03:39 AM
- Davevand
+1
-- Andy - Seattle USA
View Lazyman's profile
Lazyman
4535 posts in 1996 days
#9 posted 12-10-2019 04:17 AM
Definitely more chipout using a router bit than a table saw for finger joints in my experience. A backer board is a must.
therealSteveN
#10 posted 12-10-2019 05:09 AM
- Davevand
Me too.
I would use either this set.
Or my new favorite blade. I have the .250 one.
Seems either offers less tear out over a router bit.
View AlaskaGuy's profile
AlaskaGuy
5522 posts in 2917 days
#11 posted 12-10-2019 07:24 AM
The old “if I were you” I get a good rip blade and follow this video.
https://youtu.be/nYlA0CRDn3k
Pretty much what I did but I went with 1/4 for 1/2 inch BB
View wildwoodbybrianjohns's profile
713 posts in 156 days
#12 posted 12-10-2019 08:50 AM
- Davevand
+1
- Andybb
+2
-- Wildwood by Brian Johns: If you tell the truth, you dont have to remember anything (S. Clemens) Edit: Now where is that darn pencil/ tape measure!
Andybb
#13 posted 12-10-2019 09:07 AM
If you do decide to use a table saw then make this jig. Don’t forget to get a joinery blade that leaves a flat profile.
The blade will stay sharp whereas a router bit will start to dull after a few boxes.
I actually would probably use a regular kerf blade. It will leave a 1/8” cut.
