What can I use to vent my DC outside? Small DC using a bag, exhaust OD is 3.5"
Forum topic by MiniMe posted 12-09-2019 03:16 PM 454 views 0 times favorited 8 replies Add to Favorites Watch
View MiniMe's profile
MiniMe
310 posts in 657 days
12-09-2019 03:16 PM
I bought this guy and I would like to have the option to vent outside so I need to run a hose or some pipe to outside.
Any idea if there is such a thing like 3.5” hose?
8 replies so far
5927 posts in 3099 days
#1 posted 12-09-2019 06:11 PM
Get the 4” hose and use duct tape to make it fit.
MiniMe
#2 posted 12-09-2019 06:35 PM
- Fred Hargis
Can I use a hose clamp when the hose is larger?
#3 posted 12-09-2019 06:41 PM
You can if you’ve put the duct tape on the DC outlet, it will squeeze the hose into the tape. I recommend the wire type clamps, they’ve always worked better for me than the band type.
MiniMe
#4 posted 12-09-2019 07:20 PM
You can if you ve put the duct tape on the DC outlet, it will squeeze the hose into the tape. I recommend the wire type clamps, they ve always worked better for me than the band type.
- Fred Hargis
Oh that is what you meant by use tape :-) so I need to add 0.25” of tape all around …that could be a lot of tape but yes that could be a solution. The other would be to try to mold a 4” but I doubt it would work. I still have to go to Home Depot to look at he fittings for gas and water I thin they measure the Internal Diameter ..maybe I can find something close
View ohtimberwolf's profile
ohtimberwolf
962 posts in 2958 days
#5 posted 12-09-2019 07:38 PM
See if HD or someone can guide u to some used insulation blowing hose. L
https://www.flexaust.com/news-and-pr/insulation-blowing-hose-optimal-volume-coverage/
-- Just a barn cat, now gone to cat heaven.
MiniMe
#6 posted 12-09-2019 07:58 PM
I could try to mold a cut open pipe section like this
I might need to add two layers there which is not a fantastic solution
View ibewjon's profile
ibewjon
1169 posts in 3399 days
#7 posted 12-09-2019 11:16 PM
Look at fernco or other brands of rubber plumbing couplings. Many odd sizes available, even some to for old clay sewer pipe. You may need a short piece of hard pipe between the rubber coupling and 4” hose.
MiniMe
#8 posted 12-10-2019 01:20 AM
the 3”to3” rubber coupling works just fine. The an 3×3 elbow gas pvc fitting (male toward the DC and female to outside) and then a 3”to4” adapter did the job. I now have the option to run the exhaust straight out using a 4” pvc gas pipe, no molding no gluing
