Forum topic by bbandu | posted 12-06-2019 06:20 PM | 2676 views | 0 times favorited | 24 replies | ![]() |
Ok so I have always wanted to learn how to turn, However there has always been something that has gotten in the way. Because I have no experience with turning I have always looked but never pulled the trigger on anything. I came across a used DELTA LA200 MIDI LATHE Model 49-460 ( which is supposed to be the variable speed version). The lathe and chuck for $200, if I want a set of 5 Crown tools included it would be $300. I haven’t been able to find alot of info on a used price range for this lathe. Is this a good beginner lathe? Is $200 a reasonable price for this lathe? Or should I just wait for a better lather to come along? |
24 replies so far
#1 posted 12-06-2019 08:35 PM |
That lathe & chuck for $200 is not bad if it runs smooth and complete. Won’t know until you go look, see, & hear the lathe run. Cannot answer whether good beginner lathe until know what want to turn. Small bowls & spindle projects should not be a problem with lathe if runs good. -- Bill |
#2 posted 12-06-2019 08:46 PM |
price is pretty good if in good shape,new about 600.i had one years ago that i used for pen turning.it’s a good lathe to start with to make pens small turning’s or small bowls.mine didn’t have vs so ive now got a small jet with vs.if it’s in good shape id go for it. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#3 posted 12-06-2019 08:49 PM |
If it is in good shape, that is a decent price I would think. The sell new for $600 stand is another $170. I have had one for quite a few year. Still running strong. Good lathe for beginning. You won’t make anything real big on it. I actually went from a big lathe down to the mini because I had no desire to make big stuff. I could save some space in my little shop. -- “We all die. The goal isn't to live forever; the goal is to create something that will.” - Chuck Palahniuk |
#4 posted 12-06-2019 09:18 PM |
As others have pointed out, price isn’t bad if it runs and hasn’t been mistreated or shows excessive wear and tear. Be advised, however, that Delta discontinued this lathe a long time ago, and parts/service may be difficult/impossible. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#5 posted 12-06-2019 10:45 PM |
thats true gerry i forgot to mention that. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#6 posted 12-06-2019 11:27 PM |
Here is the lathe I mentioned above. |
#7 posted 12-06-2019 11:39 PM |
The chuck alone is probably worth half the asking price. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#8 posted 12-07-2019 01:36 AM |
oopss I miss spoke. I was thinking 46-460, which is what I have. I don’t know what the difference is but I do not know anything about a 49-460. It looks a lot like mine. I wonder if the parts are interchangeable. -- “We all die. The goal isn't to live forever; the goal is to create something that will.” - Chuck Palahniuk |
#9 posted 12-10-2019 12:04 PM |
Ok so something’s have came up and I have not picked up this lathe yet, however a couple others have popped up all for the same price. DELTA LA200 MIDI LATHE Model 49 The lathe and chuck for $200 WEN 8” x 13” wood lathe with 1/3 HP variable speed drive (New) for $200 Central Machinery Lathe with carving tools, pen press kit, assorted pen blanks and aftermarket NOVA chuck for $200 How do these three compare? |
#10 posted 12-10-2019 02:27 PM |
Unless there are problems with the Delta, I wouldn’t touch either the WEN or the Central Machinery (Harbor Freight) lathes. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#11 posted 12-10-2019 02:52 PM |
The Delta is probably a better lathe than either the HF or Wen. The HF mini lathe is not a terrible lathe and you get the pen press and turning (not carving?) chisels but you don’t say which chisels come with it so it is hard to say whether they are even worth having. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#12 posted 12-10-2019 02:53 PM |
yeah of the 3 id stay with the delta. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#13 posted 12-10-2019 10:47 PM |
I have the Delta 46-250 which is the LA200 before they changed the name. Mine came out of a Jr high school wood shop a couple years back and seems to have survived well. The only visible damage was that the belt had been broken and the point on the drive center was broke off. Likely from a drop on the concrete. Replacement belts are easy to find on the internet and even available through amazon. If I remember correctly I paid ~$150 for the lathe only; this was part of a bulk purchase hence the estimate. I later added a Nova G3 chuck. It is my first lathe and my turning is infrequent. So far it has been a solid little lathe for my needs. I just wish I could find a bed extension which is a bit of an Easter egg hunt given it has been discontinued. Here is a pic when I first brought it home. And the first bowl I turned on it. |
#14 posted 12-11-2019 09:44 AM |
Old lesson “if you snooze you lose,” certainly true for OP’s original post Could this one be in the running? Only lathe on the page that thought worth a look cause not sure if ever saw one before: Could be wrong but think this lathe a Jet 1642 even if wrong worth the money if runs good. Yes would try and bargain for better price! -- Bill |
#15 posted 12-11-2019 03:09 PM |
yeah good deals wait for no one -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
Forum | Topics |
Woodworking Skill Share
13542 |
Woodturning
3007 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2075 |
Finishing
6709 |
8187 |
34176 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7612 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5576 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
