Vintage looking "light box" on home exterior?
« back to Coffee Lounge forum
Forum topic by jimintx posted 12-04-2019 04:04 PM 928 views 0 times favorited 25 replies Add to Favorites Watch
View jimintx's profile
jimintx
934 posts in 2553 days
12-04-2019 04:04 PM
This box, that appears to have a light in the center, is on the exterior wall of a mid-70s house on my street in Houston. It faces the street, and is mounted under the eaves of the one story exterior wall.
None of us in the neighborhood, including the current owners of the home, know anything about it. It has the look of some type of emergency signal, or locator light – but that is a guess, and there is no guess on how it works.
I wondered if anyone amongst the LJ crowd that might see this post knows what these things are/were.
Any ideas, thoughts, or actual knowledge? Replies appreciated!
-- Jim, Houston, TX
25 replies so far
View pottz's profile
pottz
13687 posts in 1952 days
#1 posted 12-04-2019 06:23 PM
maybe an alarm system,have you tried tracing the wires to see what it’s connected too,if possible?
View accord's profile
accord
40 posts in 492 days
#2 posted 12-04-2019 06:37 PM
reminds me of some sort of an air raid siren from WW 2
View JCamp's profile
JCamp
1262 posts in 1519 days
#3 posted 12-04-2019 06:39 PM
One if by land and two if by sea
-- Whatsoever thy hand findeth to do, do it with all thy might
View MSquared's profile
MSquared
1152 posts in 882 days
#4 posted 12-04-2019 07:04 PM
+1 Looks like and old, rusty alarm box with a faded-out yellow/orange alert light. Break into the house and see what happens!!
-- Marty, Long Island, NY
View therealSteveN's profile
therealSteveN
6971 posts in 1542 days
#5 posted 12-05-2019 12:01 AM
- MSquared
-- Think safe, be safe
MSquared
#6 posted 12-05-2019 12:13 AM
Well, yes. That’s to be expected! ;)
View Andybb's profile
Andybb
3041 posts in 1572 days
#7 posted 12-05-2019 12:29 AM
- MSquared
+1 The vents on it make it more than just a light. Looks like it has 2 leads. One in a conduit for power and one that goes back inside maybe for a button? Maybe somebody was disabled??
-- Andy - Seattle USA
View builtinbkyn's profile
builtinbkyn
3026 posts in 1909 days
#8 posted 12-05-2019 12:58 AM
Back in the 70s, we had a lake house that didn’t get used much durning the Winter. We used to place a device in the window facing the road that looked similar to that pictured. It was to alert the neighbors that the heating system was off and the pipes were at risk of freezing and know to call someone. The box had an internal thermometer set for 55 degrees. If temps dropped below that, it would illuminate. Ours plugged into a wall socket, but this one could serve the same purpose but looks to be hardwired, with another wire connected to either a thermostat or the heating system. Or it’s just part of an old security alarm :)
-- Bill, Yo!......in Brooklyn & Steel City :)
View CaptainKlutz's profile
CaptainKlutz
3988 posts in 2462 days
#9 posted 12-05-2019 12:58 AM
Hmm, color me curious!
Can you show a picture of the inside of the box, please?
Sort of reminds me of the old (30/40’s) warning box found on Railroad crossings? That box would be mounted on side of transformer power cabinet next to road/crossing. The warning system was ancient vacuum tube and relay based detect/timer system. It used as much power as hair drier today. If it is one, the plastic light fixture on top is not the original version. It looks like a modern replacement from 60-70’s, when they removed vacuum tubes from RR controls.
That was a common control box design back before transistors. The air raid warning boxes from WWI/WWII looked same, but were deeper to hold the siren, and had louvers on side too.
jimintx
#10 posted 12-05-2019 04:34 PM
Thanks to all –
It remains a somewhat unsolved mystery, but I believe there is agreement that this thing is a warning, emergency type signal.
There’s no good or simple opportunity to trace wires as they go into the eave and disappear, so to speak. The current owner has no idea, and didn’t happen to learn about this box when they bought the home a few years back.
-- Jim, Houston, TX
View Fresch's profile
Fresch
520 posts in 2889 days
#11 posted 12-06-2019 12:39 AM
In the house are there any ~2”x3”X1-1/2” brass looking boxes on the ceiling?
If so it’s fire alarm. .Honeywell. iirc.
jimintx
#12 posted 12-14-2019 08:41 PM
I asked the owner if there was a “big red emergency button” or similar somewhere inside the house. She said they’d never noted one.
Maybe it was there once, and it’s since removed, and the sheetrock was repaired to conceal the location.
The husband works out of town for extended periods, but I will ask him once I see him around again.
-- Jim, Houston, TX
jimintx
#13 posted 12-29-2019 04:14 PM
I got to ask over Christmas, and the owners say they have no idea about what this box is, or was.
Thanks for all the thoughts about this, while it remains an unidentified curiosity.
-- Jim, Houston, TX
View controlfreak's profile
controlfreak
1607 posts in 570 days
#14 posted 12-29-2019 04:39 PM
Back in the day before sirens we had alarm “bells”. The basic ones were just a bell in a metal cabinet with a tamper switch on the front door and back. The more advanced ones had an outer cabinet insulated from an interior bell cabinet to detect an attempt to drill between the two. This one may be a 120V version which was popular when alarms were run off dry cell batteries. The strobe light on the front was added after the fact to give it a visual indicator. It is also likely that the old bell has been removed and replaced by a siren or speaker at some point in its life. If removing check for live 120v circuits and be ready to battle rust, bees etc.
View Jeff's profile
Jeff
542 posts in 4163 days
#15 posted 12-29-2019 04:46 PM
The cover has hinges on one side. Can’t they just open it up and see what’s inside? If it were my house my curiosity would have been satisfied a long time ago.
