Any ideas on shed interior?
Forum topic by Senator posted 12-03-2019 07:52 PM 587 views 0 times favorited 22 replies Add to Favorites Watch
View Senator's profile
Senator
9 posts in 999 days
12-03-2019 07:52 PM
Hi fellows,
I was wondering if you could advise me on this issue
22 replies so far
View Madmark2's profile
Madmark2
746 posts in 1199 days
#1 posted 12-03-2019 08:15 PM
Put up walls? Insulate, wire with outlets over 4’ up, lots of lights, everything on wheels and at the same height.
M
-- The hump with the stump and the pump!
View pottz's profile
pottz
7709 posts in 1595 days
#2 posted 12-03-2019 08:19 PM
Put up walls? Insulate, wire with outlets over 4 up, lots of lights, everything on wheels and at the same height.
M
- Madmark2
+1 id cover the walls with plywood or osb makes hanging or attaching things much easier and paint white to make it bright.
View sansoo22's profile
sansoo22
512 posts in 265 days
#3 posted 12-03-2019 08:54 PM
I would ask what you intend to use the shop for. That could determine what you do with the interior. If its for yard tools…well nothing…if its for a wood shop then a lot of stuff.
View BobAnderton's profile
BobAnderton
309 posts in 3401 days
#4 posted 12-03-2019 09:35 PM
I put up a 12×16 and put a 2 foot wide shelf all the way around the interior at 3 feet high and another at 6 feet high using surplus 2×4s and plywood. It massively increases how much junk I can store in there. The 3’ high shelf is about bench height and you can still wheel heavy stuff under it. Put hooks in the rafters to hang stuff from. All depends on how tall your shed is I guess.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View BurlyBob's profile
BurlyBob
6922 posts in 2876 days
#5 posted 12-04-2019 12:06 AM
Totally agree with everything Mark told you.
Smitty_Cabinetshop
16349 posts in 3229 days
#6 posted 12-04-2019 12:15 AM
Answers could go a hundred directions. What’s the shed’s purpose? I have a couple / three sheds that have been around over a century. Only one has painted inside finishes, the other two open framing. Do I care? Nope. There’s a car in one and misc. storage in the other.
pottz
#7 posted 12-04-2019 12:32 AM
i guess because this is a woodworking forum we assume he’s going to use it as a workshop,but we all know what happens when we assume,we make an ass out of you and me-lol.hopefully he’ll clarify.
sansoo22
#8 posted 12-04-2019 02:22 AM
i guess because this is a woodworking forum we assume he s going to use it as a workshop,but we all know what happens when we assume,we make an ass out of you and me-lol.hopefully he ll clarify.
- pottz
My day job is a software architect. I gave up assuming anything a very long time ago. Murphy’s law applies to everything now. If a user can screw it up they will…I don’t care if the code can theoretically NOT do that the user will find way to make it happen.
View therealSteveN's profile
therealSteveN
4670 posts in 1185 days
#9 posted 12-04-2019 02:33 AM
“Any ideas on shed interior?
Hi fellows,
I was wondering if you could advise me on this issue”
I gave up ass/u/me a long time ago, nothing here to really say much.
Off hand though I’m gonna say 4 cows. 3 to eat, one to mow the grass…....
-- Think safe, be safe
sansoo22
#10 posted 12-04-2019 02:46 AM
Off hand though I m gonna say 4 cows. 3 to eat, one to mow the grass…....
- therealSteveN
+1 except with goats because then I can use the shed as a yoga studio with goats…I hear that’s a popular thing now. Sorry Steven…I will see myself out now.
therealSteveN
#11 posted 12-04-2019 03:19 AM
Goat Yoga, whodathunkit.
View BlasterStumps's profile
BlasterStumps
1499 posts in 1050 days
#12 posted 12-04-2019 02:44 PM
About the middle of Dec, we are expecting delivery of a portable workshop building. We are planning to insulate, put up a vapor barrier and most likely drywall. I have been going back and forth about using some type of wood sheet goods on the walls.
I am planning to surface mount the all the electrics.
Lots to figure out still. Heat, light fixtures, paint, and all that.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View controlfreak's profile
controlfreak
415 posts in 212 days
#13 posted 12-04-2019 02:44 PM
My 10’x16’ shed started as storage for yard tools and overflow from the house. Now it is a shop and boy is she pissed! Right now I have finished adding power and working on insulation/ wall storage with french cleats. A heater is on it way. After that it will either be adding carts for tools and/or base cabinets with storage. Once all this is done I plan on building a smaller shed for storing all the yard tools and maybe sneak in some lumber storage too.
By that time I will probably be onto building a bigger shop or expanding what I have. To the OP like said above it depends on the use. Storage, lots of shelves and hangers. Shop, lots of outlets and a way to make a tight space work the best you can.
therealSteveN
#14 posted 12-04-2019 03:39 PM
- BlasterStumps
OSB is about the lowest cost “sturdy” sheet goods I know, and you can paint it white for a clean look, and it is ok for attaching items to the wall over it. It’s what I put up on my shops wall behind my wood rack. I needed to insulate back there, and all of that build was way in front of the drywall work. It’s held up better than the drywall. You almost have to squint to see the OSB inside, versus the OSB outside used as wall sheathing under the siding. In the after pic it’s clearer compared to the drywall.
Looking at that pic I’m just thinking I never got back to paint that OSB. I had wood I needed to move right away. Huh…
Drywall, once finished is about 4 times the cost of painted OSB.
pottz
#15 posted 12-04-2019 05:39 PM
my whole shop is covered with osb but i didn’t think about painting it until everything was setup,and i sure ain’t moving and removing everything to do it now !
