Forum topic by eldercop | posted 12-01-2019 03:25 PM | 1059 views | 0 times favorited | 19 replies | ![]() |
Hi thanks in advance guys -- "Experience is what you get the day after you needed it" Mark Twain |
19 replies so far
#1 posted 12-01-2019 03:54 PM |
What fence do you have? |
#2 posted 12-01-2019 04:17 PM |
Are you talking that when you push down on the lock lever, the fence will move a 1/16” or less as you push down on the lever. Mine does that and yes it is annoying. I’d love to know is there is something to be adjusted to halt that. My fence is a Steel City Biesemeyer style. Starrett has a rail tape that has both metric and standard. I have it and like it but I have to be careful to remember which one I am currently using. -- “We all die. The goal isn't to live forever; the goal is to create something that will.” - Chuck Palahniuk |
#3 posted 12-01-2019 04:41 PM |
Oh, sorry JB -- "Experience is what you get the day after you needed it" Mark Twain |
#4 posted 12-01-2019 04:48 PM |
I think most of them will do that unless you clamp it slightly while setting the width (I use my fence scale). I simply put the cursor on the mark, clamp it slightly, adjust if necessary, then clamp it tightly. -- Our village hasn't lost it's idiot, he was elected to congress. |
#5 posted 12-01-2019 05:26 PM |
I got a Biesemeyer fence in 1989 and retired it about five years ago when I bought a new table saw. I used the tape on the rail and was able to get excellent accuracy and repeatability with proper technique and adjustments. The technique I used to adjust the fence is to pull back on the locking handle and give it a bit of a shake from side to side as I moved it. Pulling back keeps the alignment pads in contact with the rail and the shake helps overcome static friction to make fine movements easier. Of course it also helps to keep the rail and pads waxed. The first adjustment trick is to be sure that the setscrews behind the alignment pads are making contact without the fence being clamped. If there’s space the alignment will change when you clamp it. The second adjustment I made was to shim the cursor plate to move it closer to the tape. This reduced parallax error and made the setting much easier to read. I could repeat a setting to within a few thousandths and absolute accuracy was limited by the accuracy of the tape. Speaking of which, be sure you check the stick on tape before you stick it down. Some of them have large cyclical errors, so you need to check linearity. -- Dave, Tippecanoe County, IN --- Is there a corollary to Beranek.s Law that applies to dust collection? |
#6 posted 12-01-2019 06:27 PM |
Thanks Dave -- "Experience is what you get the day after you needed it" Mark Twain |
#7 posted 12-02-2019 04:00 AM |
My Incra fence, I set to the dimension and then clamp it. Done. I’m still anal enough that I check the dimension again, anyway (with a steel Starrett scale, to boot). Got to get out of that habit- it must cost me 10 seconds per setup. -- Steven.......Random Orbital Nailer |
#8 posted 12-02-2019 03:58 PM |
Incra -- The hump with the stump and the pump! |
#9 posted 12-02-2019 09:50 PM |
+1 for Incra. Once it’s set to the blade it’a ALWAYS spot on. No guessing, wiggling, closing one eye & trying to hold your head in the same position, etc. |
#10 posted 12-05-2019 08:15 PM |
I had a Delta/rockwell contractors saw for years and it was a cut and sneak into the correct length with multiple cuts endeavor. Frustrating but you get used to it. I’ve been using a new sawstop professional for a couple of years now. I didn’t know a fence could be reliable before that. So refreshing. 1 1/8” on the rail is the same on the wood when cut. An accurate fence is such a nice thing. I hope you get satisfaction. I’ve been there. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. |
#11 posted 12-05-2019 09:53 PM |
My usual answer to any TS fence issues is to buy a Vega, and move along with a smile on your face. That costs $$$$$ though. Does your indicator have a screw on, in, or next to it? That is so you can set the tape exactly the correct distance from the blade. It’s a given if you change saw blades you may have to re-calibrate it. The indicators are only good if you use a Combo blade, and never swap out blades. Because I do swap blades for Rip, Crosscut, Plywood, etc etc etc. they have minimal, but still different widths. So I use known sizes on wood cut offs, and machined blocks to measure my cuts exactly from the fence to the blade because I can’t trust my tape is dead nutz, and to re-calibrate it every time I swap blades sux. Or you could just use a tape measure. I don’t ascribe to that because you can easily get transposition errors. -- Think safe, be safe |
#12 posted 12-05-2019 10:31 PM |
I have a lowly Craftsman 24/12, the one that comes with my table saw, and it’s absolutely nuts-on as long as I push the fence forward to keep it in place before locking it. Same idea as above, only my fence works differently. |
#13 posted 12-05-2019 11:15 PM |
It never ceases to amaze me how many people don’t know about this! -- there's a solution to every problem.......you just have to be willing to find it. |
#14 posted 12-06-2019 04:20 AM |
If looking at accuracy on measurement, I use a steel ruler and not a tape measure. and will gladly remeasure after holding down and locking the fence. The measuring tape on my rail is dead on, but if I stand to the right or left of the indicator line and look at the line, I’ll be 1/32” or 1/16” off. So I only use the measuring tape on the rail if I’m not worried about exact cuts. |
#15 posted 12-06-2019 05:52 AM |
It’s in the manual, but it’s actually pretty obvious – because you can see the thing shifting if you don’t do that! |
Forum | Topics |
Woodworking Skill Share
13148 |
Woodturning
2791 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6304 |
7862 |
32562 |
CNC Woodworking
325 |
Hand Tools
6431 |
Jigs & Fixtures
1788 |
Wood & Lumber
7245 |
1615 |
Focus on the Workspace
2619 |
1267 |
Woodworking Trade & Swap
5397 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
