Hi everybody, looking for a little advice that I am sure the knowledgeable folks here can answer. I am building table leaves for an extension table and am having problems drilling the dowel holes for the locating pins. I have 2 cheaper doweling jigs (Milescraft and General) that are useful for different purposes but each has its own issues. The General seems to be the best for this purpose and would work great as it clamps solidly to the work piece except that for some reason General made the bushings out of some kind of super soft metal. The first one lasted for about 5 holes on another project, and the manufacturer sent me another for free; however this one is just as soft and wore out to the point that the 5th positioning hole was way off. I think this tool would work work like a champ for this project if the bushings did not wear so quickly; both bushings now have oval holes instead of round.
Does anybody here know of a doweling jig (or other method) that works reliably and is accurate? I know about the DowelMax (sp?) but I can't afford that kind of money right now for something that should be simple. I need to drill 40 positioning holes (5 per side, 10 per leaf, 4 leaves). I have been practicing on scrap until I get the right tool and technique.
The JessEm doweling jig is a little cheaper than the Dowelmax (which I use) and is reported to work just as well. I have tried several of the cheapo self centering doweling jigs and found them to be worse than worthless because I wasted a lot of time trying to get them to work satisfactorily.
Woodcraft has that on sale for Black Friday but I can't wait until then, the leaves are for a Thanksgiving dinner party. What's the chance of talking them into honoring it early (probably zilch)?
I have a older version (all cast metal) and the newer version (mostly plastic) of the General 840. Just made a table leaf for a customer and used the General 840 (older version) and had no troubles.
You my consider the JessEm or Dowelmax. The Rockler Dowel Pro Jig is one you might also consider for edge dowelling. https://www.rockler.com/dowel-pro-jig
To my mind it is the bestest dowel jig suitable for any kind of cabinet/furniture making when you need accurate dowel placement
But maybe that's just my klutzness with trying to use dowel centres. I don't know. All I know what is what gave me good results when I had to use dowels for case-work, where 24"-ish widths are required.- with good precision.
So much entused was I with these devices, that I have acquired more than one of them. Alas, they are not sold any longer, so it's only on the used marketplace you will find them
JackDuran+1, Good pics of the General 840 in action, If anyone doesn't know this jig. the screw clamp is removed and holding it in place by hand. Both of mine, I leave the screw clamp on the jig.
I got the JessUm unit today from my local Woodcraft and am very pleased with it. It is very heavy and well made unlike my other jigs. I drilled the first leaf and it came out great with a perfect fit. I should have spent the money in n this one originally instead of wasting money trying to save a dime. Thanks for the suggestion! I can always rely on the great folks on this forum and have learned so much in my time here.
I started my career with one of these. (late 70's) Drilled hundreds, if not thousands of holes with it.
It put blisters on my hands, but the holes lined up.
In the past, I have made my own doweling jig; just a block of wood with a thin piece of plywood on both sides of the block which forms the letter H. The block is the exact thickness of the wood being doweled. Place the jig on the work and drill the hole approximately where wanted; then reverse the jig and drill from the other side into the second piece. Regardless of the angle of the hole, the 2 doweled holes will always line up. Cost: 0
Thanks for all of the advice here. I went with the JessEm jig and everything came out perfectly! Yes it costs money but I am very impressed with the quality and rigidity of the unit, not so impressed with the junk bit that came with it (but I can use my good bit).
Will finish edges and stain and finish after the holiday. This project was more work than I expected but I am so pleased with the way it turned out.
Yes I saw the flyer when I bought mine but couldn't wait and the store wouldn't deal. I may just find some reason to return it (actually the junky bit dulled after less than 10 holes) and buy at the new price.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
