Hi all,
Some time ago I built myself a new router table fence, ( my second) and using what I had learned up to that time I added a piece of T track on a slide that moves in and out on what you would call the Y axis. I've used it for a while now and though I'd share the idea incase anyone else finds it useful.
I made it originally to use a feather board to keep down pressure right over the router bit when routing grooves etc. away from the edge of plywood, but I've found other uses for it.
Here's a few pics.
Position feather boards anywhere you need to, or even using them as guards to keep fingers away.
I made a shop vac fitting for it for dust control for routing inside picture frames for example.
I've also added outriggers to it for adjustable stops.
Thanks for looking
Here's a few pics.
Thanks for looking
