Accurately drilling a hole in a dowel
Forum topic by paulmon posted 11-20-2019 07:28 PM 540 views 0 times favorited 13 replies Add to Favorites Watch
View paulmon's profile
paulmon
77 posts in 693 days
11-20-2019 07:28 PM
Topic tags/keywords: drill dowel
Even if you never have to do this, it’s kind of a nifty trick anyway…
https://youtu.be/v5yx1C-maRo
13 replies so far
View bondogaposis's profile
bondogaposis
5569 posts in 2909 days
#1 posted 11-20-2019 07:38 PM
Same thing can be done on a lathe.
-- Bondo Gaposis
View pottz's profile (online now)
pottz
6987 posts in 1543 days
#2 posted 11-20-2019 08:33 PM
cool tip,thanks.
View jbmaine's profile
jbmaine
64 posts in 28 days
#3 posted 11-20-2019 10:07 PM
That’s pretty neat, thanks for sharing.
View BurlyBob's profile
BurlyBob
6755 posts in 2824 days
#4 posted 11-20-2019 10:25 PM
That is a nifty idea.
paulmon
#5 posted 11-21-2019 04:45 AM
- bondogaposis
Which I happen to have, but I thought there might be others who don’t.
View Planeman40's profile
Planeman40
1467 posts in 3319 days
#6 posted 11-21-2019 03:55 PM
This brings to mind another trick to drill a hole in a dowel (or anything round) in the SIDE of a dowel AND GET IT CENTERED IN THE MIDDLE OF THE DOWEL!
Put the dowel in a drill press vise in a position to make the hole. Then take a straight piece of thin metal (I use a small 6” metal ruler) and lay it across the dowel where the hole will be. Then insert a small rod with a tapered point on the end into the drill press chuck and let the point rest upon the metal ruler at a point about in the middle of the dowel. The ruler will tilt away from level unless the point is exactly over the center of the round dowel. Move the ruler and dowel back and forth. When the ruler is exactly level, that will be the point where the hole will drill through the center of the dowel. Swap the pointed rod for the drill bit and drill away!
View HokieKen's profile
HokieKen
11521 posts in 1697 days
#7 posted 11-21-2019 04:06 PM
The idea here is good. I’m not sure the execution is so much though… He puts the drill bit in the chuck to make sure it’s perfectly aligned in the vise, right? But then he lowers the table during which it also swings sided-to-side visibly. Then once he puts the drill bit in and lowers it, he visibly swings the table back over to “eyeball” the alignment with the dowel in the chuck. Also, the drill bit visibly walks off when he starts it and when he retracts it :-/
Just a machinist’s observations :-/
-- Kenny, SW VA, Go Hokies!!!
pottz
#8 posted 11-21-2019 04:08 PM
The idea here is good. I m not sure the execution is so much though… He puts the drill bit in the chuck to make sure it s perfectly aligned in the vise, right? But then he lowers the table during which it also swings sided-to-side visibly. Then once he puts the drill bit in and lowers it, he visibly swings the table back over to “eyeball” the alignment with the dowel in the chuck. Also, the drill bit visibly walks off when he starts it and when he retracts it :-/
Just a machinist s observations :-/
- HokieKen
i noticed that too,pretty much took away any accuracy there was.
paulmon
#9 posted 11-21-2019 04:21 PM
Actually, that’s kind of the point. When you see the drill bit walk off it is the drill will self centering on the spinning object.
HokieKen
#10 posted 11-21-2019 04:29 PM
Actually, that s kind of the point. When you see the drill bit walk off it is the drill will self centering on the spinning object.
- paulmon
So then why put the drill in the chuck upside down to locate it in the vise? Guess I missed that point. Had to watch with no sound…
paulmon
#11 posted 11-21-2019 04:32 PM
If you drill it ‘the normal way’, it won’t self center. But with the dowel spinning, it makes the bit automagically seek the center of the dowel.
HokieKen
#12 posted 11-21-2019 04:34 PM
I’m tracking now. Thanks for the clarification Paul. I should have watched with sound before opening my mouth :-) I retract my earlier statement about poor execution.
paulmon
#13 posted 11-21-2019 04:37 PM
Glad you ‘fixed’ it :)
