Forum topic by controlfreak | posted 11-19-2019 03:49 PM | 260 views | 1 time favorited | 9 replies | ![]() |
Topic tags/keywords: joining I have been watching how people use AC glue and activator. I have seen people spray activator on one piece and glue on the other before joining. I watched a video recently where someone was using regular wood glue and AC glue together I think which struck me as odd. Anyway he would use AC glue on two wood surfaces to be joined and press them together. He would then spray the activator at the crack where the two boards meet. Is this enough exposure to cure the glue? I have never used CA glue but it looks interesting so I bought some. Not so much for project assembly but for making or adding onto templates and such. So is there a prefered method to using this type of glue? |
9 replies so far
#1 posted 11-19-2019 03:54 PM |
CA Glue is a near-instant bond, but is brittle and will not have as much strength as PVA wood glue. It is a way to “cheat” if you don’t have very many clamps. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#2 posted 11-19-2019 03:56 PM |
i use 2p-10 with good luck i ushally get the medium as thin goes everywhere :<))) +1 to DS Comment -- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN |
#3 posted 11-19-2019 04:04 PM |
I dont use ca much for flat work but use it quite a bit in turning, for attaching chuck glue blocks and reinforcing/filling cracks and defects. As for method of use, when attaching a block to a blank I use the thick ca applied to one surface and spray the other with a bit of accelerator, place, then use a bit of weight and let it set for a few minutes. For crack fill thin ca followed by medium then a light spray of acc. CA readily absorbs into wood, especially the thin. I only use it when I will be removing a 1/16” or more material so the surface will not have ca on it only the defect. For bigger defects/cracks I use epoxy. For templates etc you might try turner’s tape, a double sided masking tape. Holds well and doesn’t creep like carpet tape, which is more like duct tape. |
#4 posted 11-19-2019 04:34 PM |
Be careful with CA glue. On another forum a lady spilled a bottle on it on her foot. It set off and really did a very nasty burn on her foot. Getting the shoe off caused even more damage. Also not good to breath the fumes. It has it’s uses though, just requires some care when dealing with it. Makes a great finish on pens. -- “We all die. The goal isn't to live forever; the goal is to create something that will.” - Chuck Palahniuk |
#5 posted 11-19-2019 04:42 PM |
Hope this isn’t hijacking this thread. |
#6 posted 11-19-2019 06:14 PM |
I keep my 2P-10 glues in the shop fridge. I also have a long “tee” pin that is used to open the neck of the glue bottles if they get clogged. So far the glues have held up well. |
#7 posted 11-19-2019 06:16 PM |
Jon, Try storing it in a refrigerator. I buy my CA in 16 oz. bottles and then dispense into 2 oz. bottles to use. The big bottles are stored in a small fridge on the back patio and I’ve never had them go bad or dry out. The 2oz. bottles have a tapered nozzle but I also use an even smaller tapered nozzle extension stuck onto the end of that. These just sit open on my workbench and never dry out. The only issue is if the tiny nozzle clogs but that is cured by cutting off the very tip to open it up again. I get everything from www.exoticblanks.com. They’re primarily a pen-turning supplier but have lots of other nice to have stuff. |
#8 posted 11-19-2019 06:26 PM |
+1 on OSU55 approach. JON, -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#9 posted 11-19-2019 09:49 PM |
ive been using bob smith mediumCA glue on wood projects for quite a few years- projects that dont do much more than sit there. mostly scrollsaw projects. never once used that activator and havent ever had a problem. apply CA to one piece then clamp/press together for about a minute. its a strong bond. |
Forum | Topics |
Woodworking Skill Share
12690 |
Woodturning
2569 |
Woodcarving
514 |
Scrollsawing
377 |
Joinery
1659 |
Finishing
5770 |
7375 |
30717 |
CNC Woodworking
268 |
Hand Tools
5984 |
Jigs & Fixtures
1624 |
Wood & Lumber
6836 |
1515 |
Focus on the Workspace
2414 |
1230 |
Woodworking Trade & Swap
5145 |
LumberJocks.com Site Feedback
2320 |
Coffee Lounge
9345 |
