Joining in the middle of 3/4 inch board
« back to Joinery forum
Forum topic by seadonkey posted 11-18-2019 05:15 AM 358 views 0 times favorited 9 replies Add to Favorites Watch
View seadonkey's profile
seadonkey
20 posts in 1047 days
11-18-2019 05:15 AM
Hello, I’m a rookie woodworker and pretty much the only type of joinery I’ve used is pocket holes, so I’d like opinions on how best to accomplish a joint into the middle of a 3/4 inch piece of wood. I was thinking mortise and tenon, but it seems like the mortise would be really shallow and the tenon very short. I’m building a little step stool based on this:
https://www.potterybarnkids.com/products/step-stools/?pkey=s%7Cstep%20stool%7C4
my question is in relation to the parts that bridge between the two sides- is mortise and tenon the way to go there or is there some better joint for that?
Thanks in advance for your advice
-- I mostly make firewood...
9 replies so far
View pintodeluxe's profile
pintodeluxe
6014 posts in 3373 days
#1 posted 11-18-2019 05:34 AM
Mortise and tenon would be best. Dowels would also work. Even glue and recessed screws is fine. Then you can cover the holes with tapered plugs.
Lots of options.
seadonkey
#2 posted 11-18-2019 05:39 AM
Thank you for the advice, I think I’m going to go for the mortise and tenon. When it comes to the depth of the mortise the rule of 2/3rds means about .5 inch deep- do you think that’s what I should go for?
View OSU55's profile
OSU55
2450 posts in 2549 days
#3 posted 11-18-2019 01:14 PM
1/2” is fine, or you could have through tenons which show thru to the outside showing off your work.
View bondogaposis's profile
bondogaposis
5570 posts in 2911 days
#4 posted 11-18-2019 02:21 PM
For something like that I would use screws and plugs.
-- Bondo Gaposis
View Robert's profile
Robert
3569 posts in 2040 days
#5 posted 11-18-2019 02:45 PM
Through mortise and tenons with wedges. Think “chair building”.
If you don’t do it this way, the racking forces will loosen the joint, it being so shallow.
View Travis's profile
Travis
349 posts in 326 days
#6 posted 11-18-2019 03:12 PM
Pocket holes would certainly be easiest, especially since you’re familiar with them. If I were going to paint the project (as in the product links) I would go pocket holes all the way. If you’re using a hardwood and want the grain to show, want to make the project a bit more “showy,” then I would do a through M&T, either wedged or tusked, as others have said.
-- The plan is wrong; my finished piece is right.
View pottz's profile
pottz
7014 posts in 1544 days
#7 posted 11-18-2019 08:24 PM
- bondogaposis
+1
View AndyJ1s's profile
AndyJ1s
73 posts in 315 days
#8 posted 11-19-2019 01:59 AM
Single step or two step stool?
Depending on your skill level (and/or sense of adventure), you might consider sliding dovetails for the steps.
The stretcher would best use M&T on the single step.
On the 2-step, a M&T as shown on the 2-step. Or move the stretcher back flush with the rear of the sides, and dovetailed into the rear edges of the sides. There may be a second stretcher on the 2-step, across the front.
Andy
seadonkey
#9 posted 11-19-2019 05:11 AM
I’m doing the 2 step one, so there will be 4 total stretchers- on the back ones I’m just going to have them in the very back and dado out some slots for them, the ones below the front of each step I’ll give a through mortise a shot.
Thanks everyone, really appreciate it! My main reason for wanting to skip the pocket holes is really just to experiment and expand the skill-set. My skill level is extremely low, but I have a strong sense of adventure and have purchased extra raw materials!
