Spraying minwax water based polycrylic finish
Forum topic by Patrickgeddes14 posted 11-17-2019 07:34 PM 437 views 0 times favorited 11 replies Add to Favorites Watch
View Patrickgeddes14's profile
Patrickgeddes14
197 posts in 377 days
11-17-2019 07:34 PM
Directions say use synthetic brush, but can I spray instead?
11 replies so far
View Phil32's profile
Phil32
721 posts in 465 days
#1 posted 11-17-2019 07:55 PM
I have used a spray gun with good results.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit! Likewise with woodworkers.
View ChefHDAN's profile
ChefHDAN
1489 posts in 3411 days
#2 posted 11-17-2019 08:27 PM
Yes, I use the $20 Harbor Freight gun and spray right from the can, no thinning or BS, great results. After the 3rd coat I will knock down any nibs with 400/600 and then apply paste wax it does not feel “plasticy” IMO
View Axis39's profile
Axis39
109 posts in 159 days
#3 posted 11-18-2019 04:13 AM
I’ve sprayed it many times. Used one of the Wagner HVLP guns, HF Spray gun and compressor, and the last time with a nice Earlex HVLP system. All with excellent results.
Biggest thing is making sure the viscosity is correct for whatever spray gun you’re using. I’ve thinned wiht water, but like adding a bit of Flotrol to settle out the orange peel a bit better.
-- John F. SoCal transplant, chewer uppper of good wood
View JackDuren's profile
JackDuren
544 posts in 1521 days
#4 posted 11-18-2019 02:06 PM
You can use the harbor freight guns for this just remember the hotter it is the faster it dries the rougher it may come out.. I went to regular poly because I didn’t like the fast dry og waterbase….
View splintergroup's profile
splintergroup
3064 posts in 1784 days
#5 posted 11-18-2019 03:10 PM
I had about 1000 ft^2 of 6” cedar T&G boards to seal with WB poly (Minwax).
Straight from the can into an old siphon spray gun, worked flawlessly (and fast).
ChefHDAN
#6 posted 11-19-2019 01:21 PM
DAUM!!!! Jack that is one FINE poker table, love the beverage drawers!
Patrickgeddes14
#7 posted 11-23-2019 04:56 PM
So I open a new can of this stuff and notice there’s a chunky paste at the bottom. I assume this is to be mixed to make one solution, but it’s tricky to break this stuff down enough so that it doesn’t shoot out of the sprayer in chunks
JackDuren
#8 posted 11-23-2019 08:47 PM
Usually the white stuff at the bottom is what I call the sugar.the flattened of the batch. Mix it well…
Axis39
#9 posted 11-23-2019 11:44 PM
So I open a new can of this stuff and notice there s a chunky paste at the bottom. I assume this is to be mixed to make one solution, but it s tricky to break this stuff down enough so that it doesn t shoot out of the sprayer in chunks
- Patrickgeddes14
Can you take it back tot he store you bought it from and have them throw it in the paint shaker? You’ll have to let the bubbles settle some, but I don’t worry about too much, the drive home should be enough time.
JackDuren
#10 posted 11-24-2019 12:52 AM
Bubble won’t matter if it’s sprayed…
splintergroup
#11 posted 11-25-2019 03:10 PM
I always use a strainer cone when transferring the final mix into the sprayer. This saves a lot of grief!
With the WB poly, a simple screen type kitchen strainer will work well (too thick for most 190 micron paint strainers)
Some soap and water and the spousal unit will never know!
