Where do you buy your sanding pads for HF oscillating tool?
Forum topic by b2rtch posted 11-08-2019 09:40 PM 780 views 0 times favorited 10 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4897 posts in 3584 days
11-08-2019 09:40 PM
Topic tags/keywords: question sander
For years(since it came out) I have a HF oscillating tool.
I paid $19.99 for it.
It still works like a champ and I love it but I cannot find pads for it.
I do not want HF sanding pads as they are junk.
On Amazon I can find only assortments of pads with grits that I do not use.
In the past Klingspor made a special order of pads for me.
I am running out of them.
If should call klingspor again but I would like to know where you buy your pads.
Thanks
-- Bert
10 replies so far
View Lazyman's profile
Lazyman
4080 posts in 1923 days
#1 posted 11-08-2019 10:25 PM
I don’t have one. I assume you are talking about the triangular ones? Are they a different size than the ones they sell for the Bosch and other similar tools. If not the same, I would probably just buy the H&L paper you like and cut them to fit.
View therealSteveN's profile
therealSteveN
4079 posts in 1109 days
#2 posted 11-09-2019 07:12 AM
Not real sure what tool you are talking about. Is it these sleeves?
The only tool HF has that also has the word Oscillating that I am aware of is this one. But your use of the word pads, threw me off. Sleeves or tubes would be my choice.
I bought 3 of these the first week HF offered them, at least in Ohio. The price was 69 bux, but back then you could stack coupons. IIRC I paid 33 bux apiece for them.
Anyhow back to sanding medium. Everything I buy comes from Supergrit. I feel they offer a better product most of the time over Klingspor, and almost always smoke their prices on name brand items. They don’t have super fast shipping, so I plan my orders.
-- Think safe, be safe
b2rtch
#3 posted 11-09-2019 11:17 AM
This is the oscillating/tool sander I am talking about:
https://www.harborfreight.com/variable-speed-oscillating-multi-tool-63113.html
-- Bert
View Chenier's profile
Chenier
11 posts in 242 days
#4 posted 11-09-2019 04:39 PM
Klingspor’s Woodworking Shop offers sandpaper in different grits and cut to match a variety of specific different multitools (Black & Decker, Bosch, Fein, Festool, Octo, Proxxon, etc.) as well as generic “triangle”. Perhaps you can find some that will fit the HF tool. https://www.woodworkingshop.com/specialty-abrasives/ Probably worth calling them with the dimensions of your tool’s sanding pad to avoid lots of trial & error.
Ooops – just reread the OP and realize you started there. They still might have something that works off the shelf.
b2rtch
#5 posted 11-09-2019 04:57 PM
As I stated in my first post, I got the pads that I am presently using from Klingspor’s I even have a part numbers rro the different grits.
I shall call them Monday.
I was trying to find another source.
-- Bert
View wncguy's profile
wncguy
462 posts in 2848 days
#6 posted 11-09-2019 08:49 PM
I don’t know ifthey have them, but I’ve found Industrial Abrasives in PA is a great source for me on various sanding items.
https://www.industrialabrasives.com/
-- Any man can be a father, but it takes someone special to be a Dad
View Kelly's profile
Kelly
2462 posts in 3479 days
#7 posted 11-10-2019 12:35 AM
I bought a sheet of hook and loop sand paper and can cut it to fit my version of your tool, or any other than uses hook and loop. It’s a couple feet wide by about six feet long.
I tried to go back through my orders to see where I got it, but…..
therealSteveN
#8 posted 11-12-2019 05:52 AM
- b2rtch
Gotcha.
They sell pads for the Fein, which I imagine they ripped off when they started making them
I’d suggest calling, they could quickly tell you more about these, and or if it would be more cost effective to roll your own from H&L backed paper. I guarantee you would see much better results moving up to Abralon, or similar, just that it won’t last as long as H&L with an Aluminum Oxide grit. It sux as the Silicon carbide is a sharper and harder grain compared to aluminum oxide, but it’s also brittle, and will break down faster. But anything will be better than that tripe HF sells
View Rayne's profile
Rayne
1238 posts in 2075 days
#9 posted 11-12-2019 03:26 PM
Try checking your local Lowes. They should work with this model.
https://www.lowes.com/search?searchTerm=triangular+hook+and+loop
b2rtch
#10 posted 11-12-2019 04:09 PM
Thank you all for your help
-- Bert
