Hello everyone
Forum topic by jbmaine posted 11-08-2019 06:54 PM 391 views 0 times favorited 17 replies Add to Favorites Watch
View jbmaine's profile
jbmaine
14 posts in 5 days
11-08-2019 06:54 PM
Hello, Forgive me if this is not the right forum for this, but I just joined and wanted to say hello. I was lurking for a while but couldn’t join ( spam, hackers ? ) but today I could get in. I did some woodworking in my younger days but really got back into it some twenty years ago when I put my house in and had a nice dry basement to set up a wood shop. I guess you could say my skill level is somewhat intermediate , with a leaning towards the technical. I’m a retired machinist, tool & die, mold maker and I’ve carried that over precision into my woodworking. It drives me nuts sometimes over thinking, measuring, tuning up my equipment, etc. but I guess that’s who I am. I’ve seen some wonderful things made by LJ members and I’m sure I’ll learn a lot, and I hope in some ways to make a few contributions my self. I tried to post pictures but can’t seem to? I use postimage. Could someone please direct me on how to get pictures in here? Thanks Jim
17 replies so far
View GR8HUNTER's profile
GR8HUNTER
6549 posts in 1248 days
#1 posted 11-08-2019 07:08 PM
welcome 2 LJ’s
click img button above left then just browse and post :<))
View Lazyman's profile
Lazyman
4080 posts in 1923 days
#2 posted 11-08-2019 07:19 PM
If you are creating a new project post, it has a specific way to post up to 6 images for the project but you can also imbed them in with the text using the img button right above the text box as Tony mentioned. I think that img button is available for almost any text box except private messages.
View HokieKen's profile
HokieKen
11295 posts in 1674 days
#3 posted 11-08-2019 08:54 PM
Welcome Jim! Always nice to have a new member who just can’t put down mics and calipers in favor of a tape :-) As a machinist turned engineer, I know where you’re coming from! Welcome to the site.
-- Kenny, SW VA, Go Hokies!!!
View dbw's profile
dbw
319 posts in 2172 days
#4 posted 11-08-2019 09:50 PM
Lazyman is spot on. Too bad he’s lazy :).
-- measure 3 times, cut once
Lazyman
#5 posted 11-08-2019 10:19 PM
If I wasn’t guilty as charged I might come back with a clever reply…
jbmaine
14 posts in 5 days
#6 posted 11-08-2019 10:24 PM
OK, lets see if I can add pictures. This is an armoire I finished this spring ( part of a bedroom set for the mrs.) It’s made from red oak( from our property) the finish is water based aniline dye followed by several coats of bartley’s gel varnish.
Here’s my last ” shop” project. I had an old butcher block and a bunch of T track so I made an assembly table/ mobile cart/ bench/ catch all flat surface/ what ever.
sorry some of the pics are sideways, darned if I can figure out how to move them. Jim
Lazyman
#7 posted 11-08-2019 10:29 PM
The sideways pictures are one of the annoyances of smartphones and lumberjocks. A couple of ways to fix. If on your phone, pull up the picture on the phone, click edit and make any minor change…I usually just crop it a little. On Windows, pull it up in the windows viewer and it has an option to rotate it 90 degrees at a time until it is the right orientation. I usually hit the preview button to the upper right of the text box before posting just to check to see if any of the pictures has the problem.
View MrRon's profile
MrRon
5767 posts in 3779 days
#8 posted 11-08-2019 10:34 PM
Welcome! I am an amateur machinist and do all my woodworking to a machinist’s level. When you apply precision to woodworking, you are more likely to stay within woodworking tolerances. Instead of ± 1/32”, ± .001 /.003 will get you much better results. True you can’t maintain high precision with wood due to expansion/contraction, but it will be a lot closer than a fractional dimension. In machining, you machine to a dimension. In woodworking, it’s often a trial and error situation to get a good fit. Measure twice and cut once followed by sanding. That’s how you get a woodworking joint to work. Others may do things differently, but My woodworking follows my machining skills. I would probably set a practical precision limit at ± .005”; after all, you need to leave space for glue in the joint.
View BurlyBob's profile
BurlyBob
6615 posts in 2801 days
#9 posted 11-09-2019 01:56 AM
Good to have you join us. You got to start some where’s, it might as well be here.
Craftsman on the lake
3038 posts in 3973 days
#10 posted 11-09-2019 10:10 PM
Hey, proud to say JB is an acquaintance of mine here in Maine…. Welcome aboard.
117743 posts in 4112 days
#11 posted 11-09-2019 11:09 PM
Welcome to Ljs glad to have you join the fun.looks like you’ve made some very nice projects
View waho6o9's profile
waho6o9
8785 posts in 3112 days
#12 posted 11-09-2019 11:42 PM
Welcome aboard jbmaine!
I like the butcher block t track catch all, good job!
jbmaine
14 posts in 5 days
#13 posted 11-10-2019 01:54 AM
Thanks everyone, Glad to be here, Jim
View Andybb's profile
Andybb
2149 posts in 1139 days
#14 posted 11-10-2019 06:44 AM
Welcome.
Based on that Armoire I’d say you’re being conservative saying you’re in the intermediate stage :-) That’s a nice piece of furniture!
Easiest way to get a phone pic oriented properly is to always take the photo with the phone held horizontal (wide) instead of vertically. Has never failed for me.
-- Andy - Seattle USA
View pottz's profile
pottz
6639 posts in 1520 days
#15 posted 11-11-2019 02:15 AM
yeah thats some nice work glad you got on and are sharing your work,hope you enjoy it here as i do,welcome jbmaine.
