Forum topic by Newbie17 | posted 11-08-2019 04:08 AM | 1067 views | 0 times favorited | 12 replies | ![]() |
Topic tags/keywords: jet planer belt Watch the slow motion video of what is happening when I turn on the Jet 20 inch helical head planer and tell me if you think the belts jerking around is normal. Should the motor speed ramp up or is it an all or nothing operation? There is rubber dust all around the belts, even coming out of the vents and the spaces around the belt cover. (Turn on sound when watching the video) |
12 replies so far
#1 posted 11-08-2019 05:20 AM |
That’s very much how my powermatic planer starts. Single phase motor. -- Aj |
#2 posted 11-08-2019 06:37 AM |
Those belts seem to really be flopping around quite a bit. Is it possible they need to be re-tensioned? Are the pulleys tight on the shaft? Motor mounts secure? -- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo |
#3 posted 11-08-2019 11:06 AM |
+1 Check pulleys, motor mounting bolts and belt tension; They look too loose, but can be other issues? Rubber residue from belts is normal sign of wear. Significant amounts of dust means significant belt wear. Could be due misalignment (most common), loose/damaged pulley, or improper tension. Have seen cases where loose set screw in pulley groove was protruding into belt and abrading the inner edge. Could also have bad bearings requiring excess force to get cutter head moving? Investigation of wear on belts and shiny wear spots on pulley often explains exactly what is wrong. Helps to have a fresh belt for comparison if you don’t mess with belt power transmission often? A bang at start up is often referred to as ‘belt slap’. Usually means not enough tension, or need new belts as they are de-laminating between plys. Note that as belts age, they stretch and wear on bearing surfaces. This means occasional re-tension is required between replacements. PS – Always set tension on cold belts. Warm/hot belts are expanded, and shrink when cold; creating excess tension. Belt tension is almost an art form, especially when comparing long or short belts? There are a ton of references online if you don’t want to use the Jet owner’s manual recommendation for belt tension. https://www.bestorq.com/library/techinfo/whytension.pdf https://www.skf.com/binary/49-66598/12419-V-Belt-replacement-work-instructions_EN.pdf -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#4 posted 11-08-2019 03:23 PM |
+1 on checking the belt tension. Be sure to check the set screws for the pulleys, A loose screw will present with a thunk when the pulley slips and finally catches where the set screw contacts the key or flat on the shaft. |
#5 posted 11-08-2019 05:07 PM |
I’ll check the tension and set screws. Other info I should have mentioned: the planer is now 2 years old, but only used maybe 30 min total run time, ever. I’ll post another video after adjusting the screws and tension for those interested in the results. |
#6 posted 11-08-2019 05:23 PM |
In that case, replace the belts. Lack of use can cause the belts to conform to the curves of the pulleys affect their flexibility. Age may also may also explain the excessive rubber dust. -- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo |
#7 posted 11-08-2019 05:52 PM |
Whoa! +1 Long storage is hard on belts. PS – When you replace belts on tool with multiple belts, try to get belts all made from mfg lot; as they tend to be better matched in length. That or order expensive (matched length) sets from OEM. If belts are not same length, each has different tension. BTW – Your video shows one belt appears longer than the rest. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#8 posted 11-08-2019 07:44 PM |
Alright, now to find appropriate replacements belts Edit: I was reading through the document on how to check and adjust various parts of the machine and it seems that almost every part (cutters, rollers, belt tension, motor pulley alignment relative to cutter pulley…) needs adjustment. There’s evidence of misalignment of all the parts according to the manual. It’s going to be a long weekend. |
#9 posted 11-08-2019 09:50 PM |
HaHa, must be your 1st time using a commercial sized planer? Large industrial wood working tools have maintenance schedules in regular shop using tools everyday. Completely normal to have: weekly oiling and cutter checks, monthly belt tension and gear box oil checks, annual gear box oil changes, etc. After you figure it all out, it’s a 5 minute job each week, maybe 15 minutes each month, unless something needs fixing/adjusting. Won’t BS you: 1st time setup on new/rebuilt machine can be daunting. I spent an entire 8 hour day getting my first rebuilt machine setup per manual. Have now rebuilt 4 different 15”/20” planers. Only takes me 2-4 hours to check and adjust all rollers, cutter head knives, and drive train; having done it a couple times. Checking belt alignment is easy: easy peasy lemon squeezy :-) It takes longer to remove/replace the covers on enclosed cabinets, then perform the actual belt alignment. Should take 15-20 minutes at most to adjust belts? Suggest you attempt belt adjustment on the machine before buying new belts. Will help you learn what is wrong, and if you really need new belts. Unless Jet shipped cheap nasty old belts with machine, would think they should last longer than 2 years; just run a little noisy due storage deformation? Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#10 posted 11-08-2019 09:53 PM |
Sounds like the motor is jumping on start up, due to loose tentioner which will cause the loose belts scene in the video. -- Colombia Custom Woodworking |
#11 posted 11-13-2019 01:39 AM |
CaptainKlutz, I did all the adjustments you mentioned and followed the manufacturer’s instructions on how to do them for my machine. The pulley alignment wasn’t as easy as I thought it would be since the pulleys were tipped toward each other, so using a straight edge couldn’t work. That was frustrating. If you want to see what I did and the end result, here is a video below. Compare it to the first video and hopefully I did a good enough job to use the machine without problems. If you notice anything else, please let me know. https://www.youtube.com/watch?v=5T6gJpTMXP8 Also, I checked the cutterhead parallelism relative to the table and the table rollers relative to the table and all of them were perfect. The infeed roller next to the cutter is out of position by 0.02”, it should be 0.004” height difference relative to the cutterhead, but it is 0.024”. I’ve been getting indentions on boards that needed only little planing. I’m working on this adjustment now. |
#12 posted 11-13-2019 10:44 AM |
1) Looks like lack of tension was source of bang noise, and it’s fixed? The operation looks normal to me. 2) The lower pulley misalignment will be a source of belt wear. How much wear happens over time .vs. time to fix it; is the only belt question left. 3) Might want to search forums for discussion on 15” & 20” planer issues regarding leaving marks on wood; due segmented in-feed rollers when taking light cuts. Common issue on these planers, since Delta made the 13” machine they cloned. Worse, OEM manuals are horrible at explaining that these factory adjustments are only a starting point. Not going to re-post all information in this thread, since it already exists on LJ. Only add that setting the in/out feed roller heights (and in-table rollers) should be adjusted based on types of material you run. FWIW – Different OEM specify different feed roller heights, with a range of 0.020 to 0.040 being common recommendation. It’s a funny specification when compared between OEM; since most all the 15/20” Taiwan made planers come from same factory? Cheers! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2785 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6303 |
7861 |
32556 |
CNC Woodworking
325 |
Hand Tools
6429 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
