Clever store-leaves-in-table design. Where can you get this harware?
Forum topic by Sark posted 11-07-2019 02:57 AM 461 views 0 times favorited 4 replies Add to Favorites Watch
View Sark's profile
Sark
217 posts in 896 days
11-07-2019 02:57 AM
Topic tags/keywords: table table mechanism table hardware
I really like the design of this table, which I don’t think I’ve ever seen before. The leaves are kept in a storage compartment below the top. To access the leaves, you pull out one side of the table, and the other side moves outwards by the same amount. Once fully opened up, you remove the leaves, place on table and push the sides back together. Where can I find this hardware?
The Table
Storage compartment under the top
The hardware makes use of a system that uses fine cables, so that an outward pull on the end creates an outward pull on the other end. And a rail system like file-drawer glides so that the two tops glide outward easily.
In this last picture we can see the end of two leaves that are store in the compartment. The table holds two leaves, each about 16” wide.
View planecurious's profile
planecurious
9 posts in 398 days
#1 posted 11-07-2019 06:00 AM
View Sark's profile
Sark
#2 posted 11-07-2019 02:41 PM
Planecurious, thanks! The side-mount-table-slides (the 3rd link) is exactly what I was looking for. It’s a clever system, and now I’ll need to figure out the geometry of it it all to determine how many of leaves of what size can be fit into such a table.
View Samgar's profile
Samgar
10 posts in 390 days
#3 posted 11-07-2019 02:59 PM
View Sylvain's profile
Sylvain
888 posts in 3035 days
#4 posted 11-08-2019 06:45 PM
This used to be done in wood with sliding dovetails:
https://www.richelieu.com/intl/en/category/furniture-equipment/table-hardware/wood-table-slide/1015439
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
