Red oak and random orbital sander
Forum topic by dschlic1 posted 10-29-2019 04:57 PM 1594 views 0 times favorited 12 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
515 posts in 3259 days
10-29-2019 04:57 PM
Topic tags/keywords: resource oak sander finishing
I am in the process of building a large circular kitchen table from Red oak. I discovered that when I use a ROS to sand the surface, the ROS cuts the porous grain faster than the non-porous. This results in a slightly wavy surface. When I sand with a belt sander I get a very flat surface.
So I am sanding it with a belt sander up to 120 grit. I am coloring the wood with a water based dye.
12 replies so far
View wildwoodbybrianjohns's profile
2848 posts in 836 days
#1 posted 10-29-2019 05:08 PM
Card scraper could sort you out.
Is there a question?
-- WWBBJ: It is better to be interesting and wrong, than boring and right.
View EarlS's profile
EarlS
4819 posts in 3637 days
#2 posted 10-29-2019 05:17 PM
A wavy surface can be caused by inadvertently rocking the sander which moving it around. I always hold the sander on the side as low as I can, just above the pad that way I don’t put uneven pressure on the top and let the sander float, rather than trying to apply pressure.
I’ve also seen similar problems with a belt sander. It’s all about technique, IMO.
View JackDuren's profile
JackDuren
1752 posts in 2248 days
#3 posted 10-29-2019 05:38 PM
If you have belt sanded it flat and with the grain with 120grit, there shouldn’t be a lot of sanding with a ros 100,120 and 150…Your really just eliminating the belt sander scratches and working to a final final finish sand…
View WoodenDreams's profile
WoodenDreams
1455 posts in 1200 days
#4 posted 10-29-2019 05:48 PM
After gluing up panels of red oak, I use a portable 4×24 belt sander, using 180 grit. stopping quite often to feel the surface for smoothness and flatness. Able to get a nice flat surface this way. I seldom start with 150 or less grit, unless I sand by hand with and sanding block, and using a card scrapper if I feel needed.
JackDuren
#5 posted 10-29-2019 06:22 PM
- WoodenDreams
I start at 80 grit if I’m sanding glued up panels. It’s not the grit, its how well you know how to belt sand. I’ve never seen a shop use 180, it won’t sand glue…
View Stephan in BC's profile
Stephan in BC
13 posts in 3003 days
#6 posted 10-30-2019 09:06 AM
A ROS can work fine, but you’ll want to put a hard pad on it. Most come from the factory with a fairly soft pad.
-- Woodworking videos: https://www.youtube.com/AWoodworkersLife
View OSU55's profile
OSU55
2904 posts in 3278 days
#7 posted 10-30-2019 12:15 PM
Use a smoother hand plane if you want a truly flat surface.
View bilyo's profile
bilyo
1423 posts in 2391 days
#8 posted 10-30-2019 03:52 PM
I have not had that experience with hardwoods like oak. But, It has happened with wood like pine where there is a bigger difference in hardness between summer and winter wood grain. Anyway, I suggest that you make sure that the backer under the sandpaper disk is firm. A soft foam pad will be more likely to create the problem you have experienced. The reason that belt sanders don’t have this problem is that the platen is hard and rigid.
dschlic1
#9 posted 10-30-2019 05:03 PM
Thanks for all of the comments. The ROS I have is a cheap, fairly old (5 years) unit and I doubt that any parts for it are still available. My intention for posting was to inform anyone interested what I had found out.
The water based dye I am using says to use a max of 150 grit sanding. So 120 grit should work fine.
View Sark's profile
Sark
427 posts in 1649 days
#10 posted 11-13-2019 02:37 PM
Agree with Stephan in BC and Bilyo. The pad on the sander makes a big difference…as does the sander itself. Festool sells a hard pad for their ROS which I use when I want to smooth out the surface. The tool itself is smooth as butter. I also have a couple of older Delta sanders which compared to Festool are like chainsaws.
Stephan in BC
#11 posted 11-14-2019 12:17 AM
- Sark
Funny because it’s true! :D
View jbmaine's profile
jbmaine
165 posts in 759 days
#12 posted 11-14-2019 01:57 AM
Just as a tip. I’ve built a lot of things from RO and colored them with water based aniline dye. If you heat the dye before applying, it will flow into the open pores more evenly ( something about less surface tension) . You will end up with less of the tiny white bare wood spots.
