Counter top reinforcement options.
Forum topic by bmerrill posted 10-24-2019 08:04 PM 346 views 0 times favorited 12 replies Add to Favorites Watch
View bmerrill's profile
bmerrill
66 posts in 638 days
10-24-2019 08:04 PM
Topic tags/keywords: counter top live edge support
Constructing a 30”(+/-) wide, 2” thick live edge counter top for the wood shop located in 1/2 of a 2 car garage.
The top will be a glue-up of several boards of Maple.
Rear edge of the top will be continuously supported along the wall.
The front edge will be supported by pipe legs at various locations.
This will leave open spans for mobile cabinets, table saw, work bench, etc. to be stored under when not in use.
The longest span will be 7 feet.
Looking for options to reinforce the front to prevent sag and make the top more ridged without increasing the thickness.
Considering using “C” channel cut-in the underside of the top running about 6” from and parallel to the front edge. Cross supports will also be cut in at the pipe legs.
Looking for a size recommendation of the “C” channel.
Will consider other options like angle iron, or T bar as “C” channel maybe over kill and cutting in will reduce the strength of the front edge.
-- "Do. Or do not. There is no try". Yoda
12 replies so far
View JackDuren's profile
JackDuren
545 posts in 1524 days
#1 posted 10-24-2019 08:17 PM
No matter what you do the elements will play a big factor.. i wouldn’t glue that unless it was 2,3 or 4” max on boards… Now I have a 2” thick hickory top that’s 30+ 60 that’s bolted down and has no problem, but the garage is acclimated all year around without car traffic and its a two car garage….
JackDuren
#2 posted 10-24-2019 08:28 PM
We used square channel on restaurant tables and it will help some. The angle iron is the best bet, but needs to be drilled with a slot to expand and contract…
View Jim Sellers's profile
Jim Sellers
476 posts in 2899 days
#3 posted 10-24-2019 09:26 PM
2” inch thick maple with a continuous back wall cleat? Heck I don’t know why you’d need any re-enforcement on a 7’ span. And why the live edge for a work bench?
-- J.C.Sellers, Norcross, Ga. Just cut it right the first time. The best carpenters make the fewest chips.
View pottz's profile
pottz
7094 posts in 1549 days
#4 posted 10-24-2019 09:38 PM
2” inch thick maple with a continuous back wall cleat? Heck I don t know why you d need any re-enforcement on a 7 span. And why the live edge for a work bench?
- Jim Sellers
+1 i dont think id worry about it,unless your gonna have a lot of weight sitting on it continuously.
JackDuren
#5 posted 10-24-2019 10:02 PM
WOW…. We do 500 8/4 tops per week for Chlli’s, Outback,etc If its not supported in the middle it will cup.
JackDuren
#6 posted 10-24-2019 10:24 PM
pottz
#7 posted 10-25-2019 12:19 AM
WOW…. We do 500 8/4 tops per week for Chlli s, Outback,etc If its not supported in the middle it will cup.
- JackDuren
- JackDuren
i agree jack but this isn’t a 3×3 snack table,he’s supporting across the back and each end of the 7’ span,and it’s 2” thick maple,i just dont think it would be a problem really,but i may might be wrong.ymmv!
View avsmusic1's profile
avsmusic1
542 posts in 1250 days
#8 posted 10-25-2019 12:46 AM
Is there any particular reason you can’t use one more support to break up the 7’?
View Lazyman's profile
Lazyman
4203 posts in 1952 days
#9 posted 10-25-2019 12:02 PM
According to the sagulator, a 30” wide 2” thick thick sugar maple top with 84” span will sag .08” ( a little more than 1/16”) even with a 1000 pounds center load on it and with it supported along the back as well, probably a negligible amount. I think that you are good to go but if you can put at least 1 post support somewhere in the middle to cut the span, even better.
pottz
#10 posted 10-25-2019 01:14 PM
- Lazyman
yeah id say dont worry about it.
bmerrill
#11 posted 10-25-2019 02:08 PM
- Jim Sellers
- avsmusic1
When sourcing wood for the counter top found 4 reasonably priced live edge Red Maple slabs. Average wide 22” at 14’+ long. Since the garage is a multi-uses space and I’ve never done a live edge piece; wanted to try. Recently completed covering 2 garage walls with barn wood. The L shaped counter top will be against the barn wood with each leg about 13’ long. When the space is not being used for woodworking, the mobile table saw (6’ long) and mobile workbench (6.5’) will be stored under the counter top which dictates the max distance between the pipe legs @ 7’.
Thanks for all the input and the link to the sagulator.
JackDuren
#12 posted 10-25-2019 02:51 PM
- JackDuren
- JackDuren
i agree jack but this isn t a 3×3 snack table,he s supporting across the back and each end of the 7 span,and it s 2” thick maple,i just dont think it would be a problem really,but i may might be wrong.ymmv!
- pottz
Where not talking about a 3×3 on a pedestal. I apologize… I’m so use to having to warrant what I make That i forget that forums don’t … Carry on….
Jacobe furniture is the largest purchaser of lumber from Paxton Lumber company in the midwest..
We know a few thing, cause we have seen a few things…
