HF lathe switch
« back to Woodturning forum
Forum topic by Karda posted 10-23-2019 11:24 PM 260 views 0 times favorited 7 replies Add to Favorites Watch
View Karda's profile
Karda
1798 posts in 1098 days
10-23-2019 11:24 PM
I have a HF 10×18 lathe and the switch is acting up, i cleaned it but it still stops or hesitates. i would like to replace it with a paddle switch so I can turn it of in a hurry. Is there one that will fit this lathe. last time I looked on ebay the only one I could find are made for a standard handy box. here is a pic of my switch. Thanks
7 replies so far
View hairy's profile
hairy
3004 posts in 4077 days
#1 posted 10-24-2019 01:33 AM
Any switch that can handle the volts and amps required will work.
This is a wall light switch I’m using on a belt/disk sander, just about the same load you have on your lathe.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
View Lazyman's profile
Lazyman
4113 posts in 1932 days
#2 posted 10-24-2019 01:52 AM
If you aren’t worried about accidentally turning it on, you could cut the wings on either side of the switch to make at least a little easier to turn off quickly.
Check out this Shop Fox switch to see if it will fit your existing box. It says it fits a 7/8 by 1-1/2-Inch opening which seems about right.
View Madmark2's profile
Madmark2
542 posts in 1133 days
#3 posted 10-24-2019 02:28 AM
Try mouser.com, digikey.com, Grizzly.com, grainger.com, or mcmaster.com – they all should have it …
M
View LeeMills's profile
LeeMills
685 posts in 1846 days
#4 posted 10-24-2019 02:42 AM
This may work. Good for up to 16 amps. Similar to the other link but can be surface mounted if the opening is large enough.
Says it will fit a standard box OR an opening 7/8” X 1 7/8”.
If the holes don’t line up you can use a couple of self drilling or self tapping screws.
https://www.grizzly.com/products/Woodstock-110V-Paddle-Switch/D4160
Karda
#5 posted 10-24-2019 04:00 AM
the important thing is will the holes fit the screw centers, they are 3 and a 1/16 long
Lazyman
#6 posted 10-24-2019 04:13 AM
The switch should come off the mounting plate by pinching the retaining clips on the back. Remove it from the plate and measure to see if the shop Fox one I linked to above will fit the opening.
Karda
#7 posted 10-24-2019 06:16 AM
thanks i found how to take the switch out of the plate i think the one you suggested will fit thanks Mike
