Wet sanding down coats of varnish
Forum topic by BalsaWood posted 10-22-2019 07:36 PM 343 views 0 times favorited 13 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
169 posts in 1694 days
10-22-2019 07:36 PM
I’m trying to remove a bunch of scratches I missed. There are 3 coats of Waterlox on the tabletop. Would it be alright to wet sand the finish down with an orbital sander to remove the coats and get to the scratches or would that make things worse
13 replies so far
View LittleShaver's profile (online now)
LittleShaver
595 posts in 1155 days
#1 posted 10-22-2019 07:44 PM
I have no experience with Waterlox, but I would NEVER use a ROS on a finish unless I was trying to remove it. Wet hand sanding, absolutely, but with a solvent that won’t ruin the finish.
-- Sawdust Maker
BalsaWood
#2 posted 10-22-2019 09:01 PM
I have no experience with Waterlox, but I would NEVER use a ROS on a finish unless I was trying to remove it. Wet hand sanding, absolutely, but with a solvent that won t ruin the finish.
- LittleShaver
I was thinking of either mineral spirits or mineral oil which would be less aggressive. The goal is to get rid of the couple coats covering the scratches.
View Lazyman's profile
Lazyman
4080 posts in 1923 days
#3 posted 10-22-2019 10:50 PM
Are you saying the scratches are in the wood or the finish? If they are in the wood, I don’t think that there is any point trying to protect the finish. You have to basically sand all the way down to the wood anyway. If in the finish, I would try using a wax and steel wool or 3M sanding pads. I’ve never tried it with Waterlox but I frequently wet sand with Howards Feed and Wax. Of course if you are planning to put on another coat of the finish afterwards, the wax is probably not a good idea.
View bondogaposis's profile
bondogaposis
5555 posts in 2887 days
#4 posted 10-22-2019 11:01 PM
If you are trying to remove the finish entirely, there is no point in wet sanding.
-- Bondo Gaposis
View Sark's profile
Sark
217 posts in 896 days
#5 posted 10-22-2019 11:31 PM
I’ve never used Waterlux, but I think you should consider the advice from the manufacturer about what to do with scratches. It seems like very good advice.
And Lazyman raises a good point, are the scratches in the wood or in the finish? If they are in the wood, and you want to remove the scratches, you’ll be stripping and refinishing. If in the finish, then the Waterlux directions should serve you well.
View Sark's profile
Sark
#6 posted 10-22-2019 11:35 PM
Duplicate
BalsaWood
#7 posted 10-23-2019 05:06 AM
Are you saying the scratches are in the wood or the finish? If they are in the wood, I don t think that there is any point trying to protect the finish. You have to basically sand all the way down to the wood anyway. If in the finish, I would try using a wax and steel wool or 3M sanding pads. I ve never tried it with Waterlox but I frequently wet sand with Howards Feed and Wax. Of course if you are planning to put on another coat of the finish afterwards, the wax is probably not a good idea.
- Lazyman
The scratches are in the previous coats- not the wood itself.
View OSU55's profile
OSU55
2437 posts in 2525 days
#8 posted 10-23-2019 12:01 PM
Since they are only in the finish wet sand with 400 – 600 gr by hand. I’d use ms, you could sand thru and water could mess things up. Dont have to get the scratches out completely, the next coat will fill some, depends on your application method. The more left on the surface the more it will fill scratches.
BalsaWood
#9 posted 10-23-2019 11:43 PM
- OSU55
If I sand it really smooth, will the varnish have adhesion issues?
5799 posts in 3029 days
#10 posted 10-24-2019 10:34 AM
If it’s Waterlox Original, it’s has very good adhesion and you shouldn’t have a problem. It’s the urethane products that normally require a little scuff to give the surface some tooth.
OSU55
#11 posted 10-24-2019 02:31 PM
400 to 600 will provide plenty of adhesion for a urethane.
View davezedlee's profile
davezedlee
37 posts in 1360 days
#12 posted 10-24-2019 05:42 PM
the thing is, how will you know if you got down far enough to remove the scratches?
having tried exactly this, and missing “only a couple”, i ended up using liquid stripper and starting over
you’ll probably end up doing the same….
what’s the harm in trying?
the wasted time, effort, and materials lost chasing a short cut to an obvious solution, plus the experience of knowing what to do “next time”
YMMV
View TEK73's profile
TEK73
246 posts in 242 days
#13 posted 10-24-2019 05:56 PM
It seems a bit over the top using wet sanding and 400-600 grid.
Why not just go 180 or something in that range, dry sanding?
I would expect that the next coat would fix aby minor scratched from the sand-paper?
Much faster…
-- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin
