This may be a simple question, but if you don't ask you will never know…
When planning a cabinet with drawers, and the cabinet interior opening is 24", do you make your drawers 24" wide, and once everything is done, plane them down to fit?
Or do you deliberately make the drawers maybe 1/16" smaller on all sides?
The drawers will be solid wood, so planing them to fit later should work I guess?
Assuming no metal drawer slides, cut the drawer 1/16 to 1/8 smaller so the drawer won't bind. Sanding/planing to fit makes no sense when you could have made the drawer to fit to begin with.
I think there are still some unknowns. Are you making the fronts flush with the drawer boxes, dovetailed,etc? Or are the fronts screwed onto the boxes? What are you using for runners/rails if any?
I make the drawers the same size as the opening, then plane the to fit after they are glued up. That is for dovetailed, flush front, solid wood drawers done by hand. Also, I'm just doing this for fun. Someone using machines or doing it for a living might have a different approach.
Thanks for the replies. There seem to be two schools of thought here.
The drawers will have box joints in the front, the back will sit in rabbets. I will be using a face frame, so the drawers will be proud of the cabinets initially.
I will use wooden guide rails mounted to the cabinet, and corresponding slots in the drawer sides. I have used this on another cabinet, and it works great. In case you are wondering… I don't remember whether I made the drawers smaller for that cabinet, or planed them down later
Most likely I will make the drawers the same size as the opening, and plane them to fit later. Might be a bit more work, but I would like a nice snug fit.
"Most likely I will make the drawers the same size as the opening, and plane them to fit later. Might be a bit more work, but I would like a nice snug fit."
Going that route you will be able to control the snugness, making them less than, and you'll almost always end up rattling around.
You can dry assemble them, then once you know the joinery is good, take them apart, and just take some slight shavings off. Try it, do that a few times, and you will understand the words "fitting a drawer"
As said the width of the drawer box, isn't reliant in any way on the face. That is a separate issue. The only time the width needs to be changed is if you add a metal drawer slide. Even wooden rails can be let into the wooden drawer side, so not much, if any factoring there.
Then the size of the drawer isn't as critical, just make it a little smaller.
You just need to fit the guide rails to the corresponding slots.
Make your rails fit tight, and, (if they are screwed on) you can unscrew them and shave a little off on the table saw until you get them the way you want them.
I have done my wooden guides and the slot in the drawer pretty much the same way. It may look a bit experimental (the front and the handles were a bit of an impromptu project), but it works really well.
Curious: Do you have some tips on how to mount the guide rail just in the perfect position? Or is it a simple affair of measuring?
I didn't use anything to line them up other the the drawer end before assembly. The drawer guides did have a small amount of play before tightening. You could use a counterbore bit which would give a small amount of play to line up… this is the way I would do anymore…
I have done side hung drawers but don't any more. They work fine but so do simpler drawers that just rest on the frame separating the space for the drawer. I also don't use metal slides. Wood on wood moves fine with a little wax. I dovetail all 4 corners because once the jig is set up it takes no more time than a dado.
I make drawers at least 1/16 smaller than the opening. Usually I would make them 3/32 smaller. But if you are more comfortable making them full size and doing a bunch of cutting or planning that will work. But I've done enough drawers that mine generally fit fine.
I also like to make drawers full depth and let the back of the cabinet stop them. For me that has always worked fine. But my he man son put one in hard enough to push the back out. His wife gave him heck. Wasn't hard to fix. He would likely have overpowered a stop too.
I have done side hung drawers but don t any more. They work fine but so do simpler drawers that just rest on the frame separating the space for the drawer. I also don t use metal slides. Wood on wood moves fine with a little wax. I dovetail all 4 corners because once the jig is set up it takes no more time than a dado.
I make drawers at least 1/16 smaller than the opening. Usually I would make them 3/32 smaller. But if you are more comfortable making them full size and doing a bunch of cutting or planning that will work. But I ve done enough drawers that mine generally fit fine.
But my he man son put one in hard enough to push the back out. His wife gave him heck. Wasn t hard to fix. He would likely have overpowered a stop too.
Jim I agree a wood on wood drawer works well, until you start going over 25# inside the drawer, then wood rails could take you to around 40, beyond that metal slides are your best friend. In a shop condition, weight is more often found than an underwear drawer. Especially if you have hardware in them.
I read. "When planning a cabinet with drawers, and the cabinet interior opening is 24 inches" A 24 inch wide drawer could hold a LOT of stuff, Stuff has weight, some is pretty heavy. Looking back, I'm surprised at myself for not already asking about what the drawers that are 24" wide are going to hold?
No kidding. It's going to be a wardrobe… so t-shirts, underwear and other light stuff.
By the way, my shop drawers (running on oak guides) are working really well even when filled with plenty of heavy screws. Not sure how much weight that is, but it's about as many screws as I can fit into that drawer with a bit of little boxes for organization. Those drawers are about 18" wide, 12" or 14" deep.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
