White Wenge?
Forum topic by Andre posted 10-19-2019 04:43 PM 449 views 0 times favorited 9 replies Add to Favorites Watch
View Andre's profile
Andre
2840 posts in 2350 days
10-19-2019 04:43 PM
Topic tags/keywords: wenge
Was at a local wood place and came home with a couple of pieces of White Wenge, have never seen, nor even heard of it? Curious if anyone on here has seen/worked with it, has all the same crappy qualities of the regular dark stuff, I have the splinters to proof!
Not overly expensive by local standards, $12 b/f CAN. 8/4 rift cut. They had some Bocote, $83 b/f shorts.(+tax)
9 replies so far
View EarlS's profile
EarlS
3249 posts in 2893 days
#1 posted 10-19-2019 05:09 PM
Post some pictures. Never hear of it.
View Cold_Pizza's profile
Cold_Pizza
25 posts in 296 days
#2 posted 10-19-2019 05:15 PM
Lati is the name I’ve heard for it. pretty nice stuff, enjoy it
View JADobson's profile
JADobson
1446 posts in 2655 days
#3 posted 10-19-2019 07:42 PM
I’ve seen it at Windsor Plywood in Saskatoon at about the same price. Never used it though.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
Andre
#4 posted 10-19-2019 07:58 PM
Lati, on the wood data base is a match. New someone would know:)
View pottz's profile
pottz
6779 posts in 1529 days
#5 posted 10-20-2019 02:06 AM
interesting new to me too,thanks for the info andre.
View therealSteveN's profile
therealSteveN
4177 posts in 1119 days
#6 posted 10-20-2019 06:22 AM
View 4wood's profile (online now)
4wood
38 posts in 498 days
#7 posted 10-20-2019 12:48 PM
White wenge seams to be a different species with a similar grain pattern to wenge. Below is the information to compare the difference. Wenge is a little harder and heavier.
Wenge (Millettia laurentii)
Common Name(s): Wenge
Scientific Name: Millettia laurentii
Distribution: Central Africa
Tree Size: 60-90 ft (18-27 m) tall, 3-4 ft (1-1.2 m) trunk diameter
Average Dried Weight: 54 lbs/ft3 (870 kg/m3)
Specific Gravity (Basic, 12% MC): .72, .87
Janka Hardness: 1,930 lbf (8,600 N)
Modulus of Rupture: 21,990 lbf/in2 (151.7 MPa)
Elastic Modulus: 2,550,000 lbf/in2 (17.59 GPa)
Crushing Strength: 11,710 lbf/in2 (80.7 MPa)
Shrinkage: Radial: 4.8%, Tangential: 8.1%, Volumetric: 12.9%, T/R Ratio: 1.7
Lati (Amphimas pterocarpoides)
Common Name(s): Lati, White Wenge, Yaya
Scientific Name: Amphimas pterocarpoides
Distribution: Western and central Africa
Tree Size: 100-150 ft (30-46 m) tall, 2-4 ft (.6-1.2 m) trunk diameter
Average Dried Weight: 49 lbs/ft3 (785 kg/m3)
Specific Gravity (Basic, 12% MC): .58, .78
Janka Hardness: 1,200 lbf (5,340 N)
Modulus of Rupture: 18,460 lbf/in2 (127.3 MPa)
Elastic Modulus: 2,147,000 lbf/in2 (14.81 GPa)
Crushing Strength: 9,070 lbf/in2 (62.5 MPa)
Shrinkage: Radial: 6.2%, Tangential: 10.6%, Volumetric: 16.8%, T/R Ratio: 1.7
Andre
#8 posted 10-20-2019 05:24 PM
Lati at Wood Database
Lati with pics at Hobbit House
- therealSteveN
That Pen caught my attention, I wonder how many pens can be made from 10 bf ?
I turned one from Teak which to date is probable among my top 3!
therealSteveN
#9 posted 10-22-2019 06:08 AM
You would be tired of looking at Lati by the time ya got 1/2 way through them.
I saw that, and was thinking if it is that kind of showy, that is something to look for to do accents with. I would think that is quarter sawn, but further up they are talking about the 2 veneers labeled U7 1 and 2 as being flat sawn. I see box lids, drawer fronts…...
-- Think safe, be safe
