Dust collection planning
Forum topic by flamingoezz posted 10-19-2019 02:05 PM 321 views 0 times favorited 7 replies Add to Favorites Watch
View flamingoezz's profile
flamingoezz
14 posts in 1501 days
10-19-2019 02:05 PM
I’m picking up my first dust collector. Do to my shop orientation, it is going to be in a corner of my garage.
I’ve read that using the largest diameter duct you can will be best, but due to my configuration I can either run one 6” at a 45 degree across my garage (from one corner toward the opposite one; or I can run two lines more directly and cap whichever not in use. Would I benefit from shorter runs with 4”?
The DC is 1100 CFM 1.5 HP if that helps.
Thanks for advice!
7 replies so far
View pintodeluxe's profile
pintodeluxe
6004 posts in 3358 days
#1 posted 10-19-2019 04:32 PM
What diameter impeller does your DC have?
I’ve found that fans 14” or so (and bigger) perform better than the HP rating would indicate.
View pixeltim's profile
pixeltim
11 posts in 1447 days
#2 posted 10-19-2019 05:46 PM
I have a 20 year old 1.5hp Delta that I use. It’s at the far end of the shop. It’s about a 40’ run to the table saw, jointer and planer. I’m using 4” spiral pipe with one 90 degree corner (wide sweep). I only use one tool at a time so it’s worked fine for me.
I just upgraded to the cool iVac automated setup with auto blast gates, it’s silly for my situation, but very cool and handy.
Btw, I have a few extra 90s, wye’s, connectors and blast gates available.
flamingoezz
#3 posted 10-19-2019 11:11 PM
11” impeller
I ve found that fans 14” or so (and bigger) perform better than the HP rating would indicate.
- pintodeluxe
- pintodeluxe
View ibewjon's profile
ibewjon
1040 posts in 3338 days
#4 posted 10-20-2019 12:55 AM
My DC is in the corner as well. It is an old north state 2 HP that I converted to the jet pleated filter and vortex cone. It was never rated for CFM 25 years ago. I ran 26 guage steel duct, 5”, with long radius 90’s. I built my own y fittings with a spot welder. I split right after the input, and wrapped one wall about 3’ high. For the other wall, I went up over the ceiling, then along the other two walls. 4” drops off the 5” main and a blast gate at each machine. This saved running everything up to the ceiling. It works great, and the longest run up over the ceiling is over 50’. I run one tool at a time.
View Redoak49's profile
Redoak49
4245 posts in 2533 days
#5 posted 10-20-2019 01:31 AM
I think that 6” ducting is too large for that dust collector . It will pull nowhere close to 1100 cfm.
ibewjon
#6 posted 10-20-2019 09:44 AM
Yes, I agree. 6” is too large. You need to use 5”. Makes a huge difference. 6” is about 50 percent larger than 5”.
View Jim Finn's profile
Jim Finn
2754 posts in 3466 days
#7 posted 10-20-2019 12:17 PM
I ran my dust collector metal duct along the wall on the floor, then up 2-3 feet to each machine. This saves a lot of duct going up to the ceiling and back down to the machines. I arranged my shop to accommodate this set up. Works well for me.
-- No PHD just a DD214
