Question for Woodturners
« back to Woodturning forum
Forum topic by ScooterG posted 10-16-2019 02:42 AM 425 views 0 times favorited 6 replies Add to Favorites Watch
View ScooterG's profile
ScooterG
20 posts in 197 days
10-16-2019 02:42 AM
Topic tags/keywords: question
Just picked up a used lathe at an estate sale for $100. One the cheaper type with 36” bed, 4 speeds achieved by changing belts on pulleys, etc. The lathe came with a faceplate, but not a drive center with a spur for turning long, smaller diameter stock. The lathe has the screw type spindle on the headstock. Most of the drive spurs online are the taper type. Just learning how to turn so, this would be an inexpensive machine to learn on.
So the question: can a drive center with a spur be purchased for this machine? If so, any suggests where?
Edit- this machine does not have a taper headstock. The threaded headstock is solid. Not sure how to add pictures?
-- Scooter G Designs
View Lazyman's profile
Lazyman
4113 posts in 1932 days
#1 posted 10-16-2019 03:52 AM
A brand and model number or a picture of the headstock at least would help.
View WoodenDreams's profile
WoodenDreams
806 posts in 455 days
#2 posted 10-16-2019 07:37 AM
Picture or brand and model # helps. Many places to purchase the centers, chucks and assecories. Grizzly, Woodcraft, Rockler, Wood Turning association sites, etc.
View davyj's profile
davyj
46 posts in 3395 days
#3 posted 10-17-2019 02:11 AM
penn state ind. catalog and woodturningz.com the z is used instead of s, woodturnerscatalog.com all 3 are wood turning only catalogs web site and get them started.
-- retired GM/Delphi , Retired USN/USAFR
View Phil32's profile
Phil32
703 posts in 448 days
#4 posted 10-17-2019 03:10 AM
The spur center for most lathes has a #2 Morse taper If the hole through your spindle shaft is 5/8 – 3/4”, a drive center with that taper will work. Some small lathes might use a #1 Morse taper.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View Wildwood's profile
Wildwood
2760 posts in 2679 days
#5 posted 10-17-2019 07:22 PM
At a loss to understand whether your lathe has a Morse taper or plain solid threaded spindle (no hole)? Until we understand what you have unable to help you.
Finding a 2 or 4 prong MT 1 or MT2 drive center easy to do if spindle both threaded & hollow. If all you have a solid threaded spindle might be little more difficult. A chuck might be a better option.
-- Bill
View Woodknack's profile
Woodknack
12929 posts in 2924 days
#6 posted 10-18-2019 12:44 AM
For that machine I don’t know, but threaded spurs can be purchased.
