Forum topic by Jimothy | posted 10-15-2019 11:26 PM | 1028 views | 0 times favorited | 6 replies | ![]() |
So my question applies to two things. And I know this is a very noob thing to do but it was with an art project i didnt care about much. Basically i had some gaps in certain areas of my project which I filled up or “caulked around ” with Lepage no more nails, then painted one coat of oil based black paint over the no more nails (and the whole project) when it obviously wasnt dry since it had only been about 2 hours since I put on the no more nails… it was slightly harder then when first applied but definitely not dry. Can the no more nails dry underneath wet paint once the paint dries…like does the paint breathe enough to let air through for it to cure eventually? Or will it forever be soft and uncured underneath?Similarly as what i did to the no more nails, I also gave the whole thing a second coat of paint before the first coat was dry (it was very tacky). I realized this is stupid but I was just curious if it would all work out. So basically heres the question, will my no more nails and tacky wet first layer of paint dry eventually underneath my top thick layer of paint or is it doomed? Thanks y’all |
