hi what can i use to seal end of wood in cold weather. wax won't get warm enogh, elmers glue, anchor seal, or paint won't dry. what can i use when its cold thanks Mike
Have an old pot & frying pan to melt my paraffin wax on a 2nd hand hot plate! Dip whatever blank want to end seal. Use boxes of canning wax blocks and never let those pots got empty will add blocks as needed.
Have used latex paint on sunny day or in my unheated shop during winter to end seal too!
Dipping lot less messier than brushing even if have to dip couple times to completely seal. Lot cheaper than anchor or green wood sealer. They make two kinds of anchor seal one for warm weather & one for winter. If going to use latex do in same place you turn, just put something on the deck in case of drips & allowing to dry.
I heat in a crock pot when the weather gets cool the wax won't heat, when i have don't it when it is cooler the wax drys to fast. I am not heating in kitchen and carting it out side, I stumble alot. there for when it is cold wax is out
When any procedure doesn't work for you with equipment you have; look around for a solution. Solutions don't have to cost much money if go out and have look.
Woodturners often shop local yard sales, thrift stores selling used items to find inexpensive solutions. Cannot tell you how many turners have found second hand items for not much money. Talking about anything from latex paint, coffee grinders, wheels from skates, and hot plates.
Paint stores or big box paint departments often have wrong colors or open containers they will sell for next to nothing, but have to ask! Coffee/spice Grinder often found at thrift stores and yard sales for next to nothing. Grinding chips or other materials to fill cracks. Same for skate wheels will need disassemble from skates for making homemade steadies. Also hot plates also available at these venues too.
thanks for the suggestion, the PVA sealer looks good an dthe price is right. I do rummage sales but that only works when I know what I am looking for. In this case i need and end sealer that i can use when it is cold and I don't know what that is
I use latex paint that I get free from the town recycle center. They are happy to get rid of it. I bring a new paint can from a paint mfg. that is cheap to buy and fill it with exterior latex.
I bet the pva primer would work great. I will have to look into that too.
I buy titebond 2 glue by the gallon, and it works great as a sealer too. But more than $10 a gallon. Tried the old latex paint. Did not seem to do so good for me.
glue dries slow any way but if it is cold it dries slower, I am going to look at the PVA the add said fast drying worth a try. let me know what you find out
What i do in the cold is apply a wax based product then use a torch to heat it and should wick onto the wood. I just wait til the solvents have evaporated and don't point the torch straight at it, kind of slowly bring the side of flame close enough til i see it melt and wick
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
