Roughsawn bench for mudroom closet and cubby organizer
Forum topic by Patrickgeddes14 posted 10-12-2019 08:10 PM 620 views 0 times favorited 4 replies Add to Favorites Watch
View Patrickgeddes14's profile
Patrickgeddes14
202 posts in 419 days
10-12-2019 08:10 PM
Customer says she wants roughsawn, which I think with a few coats of urethane will be smooth enough to sit on without scratching right?
View Rich's profile (online now)
Rich
5134 posts in 1193 days
#1 posted 10-12-2019 08:29 PM
Maybe, maybe not. You possess the perfect tool to test it with though. (Hint: you’re sitting on it)
Or, if the idea of sliding your bottom up and down the bench doesn’t appeal to you, you can take a cloth towel, or put on a cloth glove, and slide it along checking for anything that catches it.
View Geraldsh's profile
Geraldsh
11 posts in 813 days
#2 posted 10-12-2019 08:39 PM
Depends what kind of wood it is but usually a bit of hand sanding will knock off the splinters and still give that roughsawn look. A high gloss will take away from the rustic look if it g ets too shiny.
Patrickgeddes14
#3 posted 10-12-2019 09:24 PM
What kind of finish would you use. Also, I’m not sure which white paint and primer for the mdf I should use. Simple I know, but what do you use?
View Sylvain's profile
Sylvain
929 posts in 3103 days
#4 posted 10-14-2019 01:24 PM
You can plane the board and then use a “polissoir” to change the texture as explained here
Gregg also explains how to make a “polissoir”
and his experiences
Not precisely “roughsawn” but might please the customer.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
