10-12-2019 06:18 PM
Topic tags/keywords:
question
planer
biscuit joiner
router
jointer
plane
milling
shaping
joining
I’m about to make a 10’ by 42” table top – appx. I’ll be using three wide pieces of larch. One of the pieces was closer to the bark than the other two and this piece has steep edge angles. In order to get the max width from this piece I plan to cut straight parallel lines on the edge – but not back to the depth of the radius along the edges. I want to cut the straight lines along both edges where I end up with only about 3/4” right angle edge (to the top of the board). Then I want to cut a rabbet along both edges that will reach the full depth of the bottom edge angle. Then I want to glue in a piece(s), full length of the edges, which will fill the rabbet (plus just a little, which I plan to plane smooth to the larch board. That’s my ‘plan’ (at this moment) – any help on how I can be successful at this I would appreciate it – also, what type of wood would you suggest as the filler boards? Thanks, I always appreciate the feedback. I’m posting this on two different forums if you happen to see this there.
-- Develop your character -- for it becomes your destiny. Jerry - Mannford, Ok
0 replies so far
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13194 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2812 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
568 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
416 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1891 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6338 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7903 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32741 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
329 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6450 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1803 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7275 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1631 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2630 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1272 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5412 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2396 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9655 |
