Oval mirror frame
Forum topic by stripit posted 10-09-2019 06:00 PM 236 views 0 times favorited 5 replies Add to Favorites Watch
View stripit's profile
stripit
37 posts in 2556 days
10-09-2019 06:00 PM
Hi. I want to make oval mirror frame for christmas for grand daughter. I have Rockler’s elipitical jig, but can not find any video for an oval frame. One good one on making a circle, but not oval, I think I can use it but would like to see an oval one made.
Any suggestions would be helpful.
Thanks Joel
5 replies so far
View therealSteveN's profile (online now)
therealSteveN
3914 posts in 1087 days
#1 posted 10-09-2019 09:22 PM
You have 2 choices.
Solid, usually done with plywood, or a really large piece of wood, well maybe a very small mirror. This is cut from one piece of stock, and gives greater continuity of the piece so you are not seeing joints.
Segmented, this is going to be made of solid wood segments, and it does have joint lines. It also is the ascribed method of doing these.
Jimmy D making a solid pattern, then using it to make a segmented frame.
Another one where he just makes a few segmented frames
The second one shows the difference you will see on a segmented join versus a simple round, where all the angles are same. Degree is driven by width, length of the pieces, plus the number of them. Those “Miter Set” miter gauge setting blocks are an investment, but they are dead on accurate.
Miter set
Have fun.
-- Think safe, be safe
View Underdog's profile
Underdog
1403 posts in 2548 days
#2 posted 10-09-2019 09:54 PM
David Springett details a home made oval turning attachment for the lathe in one of his books:
https://www.youtube.com/watch?v=LX12OFJHQlg
I’ve always wanted to make one, but just never got my round tuit.
-- Jim, Georgia, USA
View Think0075's profile
Think0075
8 posts in 238 days
#3 posted 10-09-2019 10:00 PM
View Sylvain's profile
Sylvain
881 posts in 3012 days
#4 posted 10-10-2019 10:11 AM
When I saw Jimmy D making thin strips, I first thought he would do a bend lamination to produce two half ellipses.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
stripit
#5 posted 10-11-2019 02:25 PM
Hi. Thanks to all who wrote, I finnly figured it out. After talking to Rock;er tecch support (for 1.2 hr) I deecided they were no help. I went back and played with a while longer,and got it I wanted 8” x 12”, but could only get it down to 10 1/4” x 13 3/4”but it worked.
One problem I had was the cord and hose for DC got tangled up and I had to stop everry couple of passes.
Other then ttat it went pretty good, think I’ll hange them from the cieling.
I was using 1 1/4” pine (a 2” x6”) which I made into a octagon with 2 long sides. It was 13 1/2” x 16 1/2: by 3” w.
Thanks Joel.
PS when I finish the walnut frame I will post it.
