Is it just me or are Stanley coping saw blades crap?
« back to Hand Tools forum
Forum topic by weedeater64 posted 10-08-2019 12:55 PM 645 views 0 times favorited 14 replies Add to Favorites Watch
View weedeater64's profile
weedeater64
62 posts in 897 days
10-08-2019 12:55 PM
What’s a decent brand that is not stupid expensive?
14 replies so far
View Pyrolev's profile
Pyrolev
3 posts in 639 days
#1 posted 10-08-2019 01:40 PM
Found this post by Paul Sellers. In it he writes he has been using coping saws for over 50 years. He uses Zona Tool blades. See his post below.
https://paulsellers.com/2014/11/coping-and-the-costs-of-coping-saws-and-blades/
Disclaimer: I have not used these blades myself, but they do look pretty nice, and are not particularly expensive.
https://www.zonatool.net/cat/coping-jewelers-mini-hack-blades-saws/coping-blades-and-saws/
View HokieKen's profile
HokieKen
15158 posts in 2024 days
#2 posted 10-08-2019 02:06 PM
I have also heard good things about the Zona blades. I bought a pack of Olson blades several years ago and have been satisfied with those. I don’t use a coping saw all that often though so I haven’t really tried any other brands.
-- Kenny, SW VA, Go Hokies!!!
View Eric's profile
Eric
216 posts in 1123 days
#3 posted 10-08-2019 02:09 PM
It appears Olsen and Zona are now the same. If that’s the case, Woodcraft has Eclipse coping saw frames and Olsen blades.
-- Eric
View DS's profile
DS
3581 posts in 3306 days
#4 posted 10-08-2019 04:35 PM
I’ve had good results with the Olsen blades. Woodworkers Source sells them here in Phoenix.
View Ocelot's profile
Ocelot
2621 posts in 3524 days
#5 posted 10-08-2019 07:34 PM
I bought Olsen blades from toolsforworkingwood. I don’t know any better since it’s the only blades I’ve had. They seem ok.
-- I intended to be a woodworker, but turned into a tool and lumber collector.
View therealSteveN's profile
therealSteveN
6475 posts in 1460 days
#6 posted 10-08-2019 07:52 PM
I use a fret saw, which is generally a shorter length blade than a coping saw, so I am not certain if they have the longer blades, but I use the Pegas brand blades, and really like them.
As much as the blade getting used I feel the frame has as much to do with the equation as anything, and soundly suggest the Knew Concept saw to be the best, by far. There is a reason they cost more.
It appears Joel sells the longer Pegas blades
-- Think safe, be safe
View dscheidt's profile
dscheidt
33 posts in 506 days
#7 posted 10-09-2019 01:33 AM
It appears Olsen and Zona are now the same. If that s the case, Woodcraft has Eclipse coping saw frames and Olsen blades.
- Eric
They’re both owned by the same holding company (which also owns foredom flex shaft tools, and probably other stuff). I’ve bought olsen coping saw blades at one of the Borgs, they work as well as I can use a coping saw.
View RRBOU's profile
RRBOU
231 posts in 3178 days
#8 posted 10-09-2019 02:05 AM
I am even worse as in my opinion anything after about 1980 with the Stanley name on it sucks. Feel the same way about CRAPSMAN also.
-- If guns cause crime all of mine are defective Randy
View bandit571's profile
bandit571
26741 posts in 3569 days
#9 posted 10-09-2019 02:18 AM
Olsen blades in my Disston No. 10 coping saw. And my Atkins No. 50 coping saw…..and about 4 other coping saws…
As for that Craftsman hater….Craftsman NEVER made a tool, of any sort. But, they did sell a lot of tools made by other companies…..
RRBOU
#10 posted 10-09-2019 02:22 AM
You did read my post did you not. I stated anything with the names on them not made by them.
View Robert's profile
Robert
4053 posts in 2366 days
#11 posted 10-09-2019 01:39 PM
Pegasus ++
View smallerstick's profile
smallerstick
31 posts in 2063 days
#12 posted 10-09-2019 01:57 PM
I have used the coping saw blades sold by Lee Valley and am very pleased with them.
-- Peter
weedeater64
#13 posted 10-09-2019 04:35 PM
- therealSteveN
I don’t doubt they are the best as I’ve seen enough people I sort of trust on the web saying so. As much as you can trust strangers on the internet anyway.
That said, $160 for a coping saw? They definitely saw their customers coming. No pun intended.
View SMP's profile
SMP
2678 posts in 791 days
#14 posted 10-09-2019 06:45 PM
I also buy the Pegas from Tools For working wood and am pleased with them. Fyi, i believe Rocklet sells the zona if you want to pick something up locally.
