Mandrel type for 10-24 insert
« back to Woodturning forum
Forum topic by Pixelthinker posted 10-04-2019 02:29 AM 372 views 0 times favorited 11 replies Add to Favorites Watch
View Pixelthinker's profile
Pixelthinker
6 posts in 147 days
10-04-2019 02:29 AM
Topic tags/keywords: lathe mandrel 10-24
I need to turn wood with a 10-24 insert. What type of mandrel do I need for attaching a 10-24 thread to a lathe with a 1”x 8tpi spindle?
11 replies so far
View Kenbu's profile
Kenbu
36 posts in 2523 days
#1 posted 10-04-2019 11:19 AM
You could mount 10-24 all-thread or a piece of bolt in your chuck. Or invest in a set of collets, for more accuracy.
Ken
View ibewjon's profile
ibewjon
1259 posts in 3435 days
#2 posted 10-04-2019 12:36 PM
What are you trying to do? 10/24 is pretty weak connection. Sanding, or actually turning?
Pixelthinker
6 posts in 147 days
#3 posted 10-04-2019 03:15 PM
- ibewjon
I’m turning, and yes it is a weak connection. But I’ve seem finials done that aren’t any bigger. Specifically I’m making a craft knife handle. I’ve done one using a pen tuning mandrel but that leaves a hole through the wood, which I’m trying to avoid.
Pixelthinker
6 posts in 147 days
#4 posted 10-04-2019 03:17 PM
Ken
- Kenbu
The all-thread makes a lot of sense. Then graduate to the collets at some point.
ibewjon
#5 posted 10-04-2019 03:25 PM
Look for a higher grade bolt, a grade 5 or grade 8, which are stronger than standard bolts. I don’t know if #10 bolts come in a better grade but it is worth a look. Also some stainless bolts are a harder grade.
Pixelthinker
6 posts in 147 days
#6 posted 10-10-2019 07:48 PM
HW store didn’t have high grade 3/16” bolts but they did have stainless. Jerry rigged setup was wonky but worked with a lot of patience. Of course I had to start with a hard to work wood (black palm), so it should be easier from now on. The aluminum insert I used was the weakest point. I may try brass next time. Anything stouter also has a larger diameter, making it less suitable for this particular use. Thanks everyone for the advice!
https://s3.amazonaws.com/vs-lumberjocks.com/pz6c6js.jpg!
View TheDane's profile
TheDane
5743 posts in 4305 days
#7 posted 10-10-2019 09:59 PM
Thanks for posting this … nice work! Quite often, when somebody asks a question like yours, we never get to see the end result!
View SMP's profile
SMP
1809 posts in 548 days
#8 posted 10-11-2019 02:39 AM
Beautiful! Sure beats my aluminum one with 30 years of oxidation!
Pixelthinker
6 posts in 147 days
#9 posted 10-11-2019 02:48 PM
- SMP
LOL. Thanks! Need to come up with a fabricated cap now.
Pixelthinker
6 posts in 147 days
#10 posted 10-11-2019 02:48 PM
- TheDane
Thanks!
View MrRon's profile
MrRon
5831 posts in 3886 days
#11 posted 10-11-2019 08:04 PM
You could get a 10-24 socket head cap screw, cut off the head and chuck it in a 3 jaw chuck in the head stock. SHCS’s are grade 8.
