Repairing Damage After Removing Trim & Rosettes
Forum topic by Jenbrunelle2 posted 10-02-2019 10:04 PM 255 views 0 times favorited 4 replies Add to Favorites Watch
View Jenbrunelle2's profile
Jenbrunelle2
3 posts in 19 days
10-02-2019 10:04 PM
I am in the process of painting my master bedroom furniture. The furniture is made by Pulaski and the original finish was a dark stain. As reflected in the picture attached, in removing the trim and rosettes from the dresser, nightstands and armoire there was quite a bit of damage done. I believe the easiest way to repair the damage would be to apply a wood veneer but would appreciate any input anyone may have.
Thank you,
Jennifer Brunelle
View DrTebi's profile
DrTebi
323 posts in 3779 days
#1 posted 10-02-2019 10:27 PM
I think you forgot to attach the image :)
View DS's profile
DS
3303 posts in 2933 days
#2 posted 10-02-2019 11:06 PM
If indeed you are painting and not staining, then I recommend polyester auto body filler. (Bondo)
If you will be staining and adding a clear coat finish, then veneer or wood filler may be more appropriate.
I think there are limits for photos on a user’s first post… so that is probably why no photo attached.
Welcome to Lumberjocks!
Jenbrunelle2
3 posts in 19 days
#3 posted 10-03-2019 03:09 AM
Would applying wood veneer work?
Jenbrunelle2
3 posts in 19 days
#4 posted 10-03-2019 03:12 AM
I will try to upload the photo again.
