Raise the grain before or after staining
Forum topic by dschlic1 posted 10-01-2019 06:16 PM 1239 views 0 times favorited 11 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
515 posts in 3255 days
10-01-2019 06:16 PM
Topic tags/keywords: question oak finishing
I am building an oak table. I will be using an oil based stain and a water based finish. Should I raise the grain before applying the stain or afterwards?
11 replies so far
View Axis39's profile
Axis39
567 posts in 883 days
#1 posted 10-01-2019 06:19 PM
Before.
Best to avoid sanding after staining until finish has been applied.
-- John F. SoCal transplant, chewer uppper of good wood
View OSU55's profile (online now)
OSU55
2900 posts in 3275 days
#2 posted 10-01-2019 08:53 PM
Always before coloring, but what stain are you using? If the typical box store stuff like minwax and most others they have a bit of solids/resin to hold the dye and pigment in and to the wood surface, and seals the surface. No pre-grain raising usually required. Test on scrap, depending on sanding/prep there might be a few whiskers that stand up, but a film building wb finish will be above them. Solvent dye usually has no solids and would need pre raising with a wb finish.
View Rich's profile (online now)
Rich
7567 posts in 1875 days
#3 posted 10-01-2019 09:22 PM
Oil based stain won’t raise the grain. I do have to ask why you’re using a waterborne topcoat on it? Oil and water don’t mix, and that goes for finishes as well.
View Andybb's profile
Andybb
3346 posts in 1889 days
#4 posted 10-01-2019 10:06 PM
Oil based stain won t raise the grain. I do have to ask why you re using a waterborne topcoat on it? Oil and water don t mix, and that goes for finishes as well.
- Rich
+1 There are great products both OB and WB but I’d stick with one or the other for the whole process.
-- Andy - Seattle USA
View AlaskaGuy's profile
AlaskaGuy
6775 posts in 3595 days
#5 posted 10-01-2019 10:29 PM
I have successful
- Rich
I have successfully used water based/born clear topcoat over oil stain. As I understand you must make sure the stain is complete dry. I have the stain a full week to day in a heated shop.
I build these cabinets to match (the best I could) my blood wood kitchen. I couldn’t find anymore blood wood at the time so I use sapele wood. I stain them with Old Master’s Oil stain and top coated with Tagret’s EM 2000 6-7 years later no regrets. Maybe I got luck but I did research and try on scrap first.
Andybb
#6 posted 10-01-2019 10:44 PM
Very true. I just hate waiting and guessing if the oil based stain is completely dry and what interaction they will have. If you’re sure its really dry and cured you should be ok.
View BurlyBob's profile
BurlyBob
9404 posts in 3551 days
#7 posted 10-02-2019 12:29 AM
Charles Neil suggested I use shellac after letting the Danish oil dry before spraying a WB varnish. He recommended a half pound cut. I did a 1 pound cut and it seemed to work just fine. I don’t see why it wouldn’t work for a paint finish as well. You might consider contacting him for some advice.
7297 posts in 3779 days
#8 posted 10-02-2019 10:34 AM
Alaska guy, you really nailed that look…well done! The advice above is all golden….most oil based stains have some kind of binder that will seal the wood, and if cured the waterborne finish will be fine. But if you’re nervous about it, a coat of dewaxed shellac between them will solve any problems.
dschlic1
#9 posted 10-02-2019 03:29 PM
Locally I can’t source WB stain. And I don’t want to wait for OB finish to set.
View ChefHDAN's profile
ChefHDAN
1829 posts in 4135 days
#10 posted 10-02-2019 03:32 PM
My usual go to with my cherry furniture is 4-5 coats of BLO and then a WB topcoat, but I do wait at least a week until I start the topcoat
View therealSteveN's profile
therealSteveN
9241 posts in 1860 days
#11 posted 10-02-2019 05:54 PM
AK those cabinets are fantastic, nice look, great color. I absolutely cannot see the huge draw to WHITE, stark and glaring over something as warm and homey as those.
-- Think safe, be safe
