New Dewalt 735x leaving scratches
Forum topic by CrankAddict posted 09-30-2019 03:10 PM 505 views 0 times favorited 10 replies Add to Favorites Watch
View CrankAddict's profile
CrankAddict
114 posts in 718 days
09-30-2019 03:10 PM
Hello,
I bought a 735x about 8 months ago right after moving and it took me several months to get my garage set up to be ready to work in. Then I managed to break my hip and lose several more months. So here I am now with an 8 month old planer that is “new” and yesterday when I sent a piece of walnut through it it came out with parallel scratches on the one side (they are not raised, they are scratches that your finger nail can catch in). I have read about blades being messed up (either a chip or a burr) but when I took the top off and inspected all blades (very carefully with a bright light) I could not see any imperfections whatsoever. Is there something else I need to be checking on this thing that could be causing this? I looked at the rollers and didn’t feel anything. And I know it’s not on the bed because this piece only went through face up (on a sled) so it had to be something above it that caused it. And finally, just to ensure the rough wood wasn’t scratched and the planing was just exposing the scratches, I flipped the board over and it produced similar scratches on the other side.
Thanks!
Jeff
10 replies so far
View dbw's profile
dbw
467 posts in 2552 days
#1 posted 10-22-2019 11:47 AM
Flip the knives, i.e., use the other edge. If this doesn’t solve the problem then you have a warranty issue.
-- Measure twice, cut once. If you cut it too short get a wood stretcher.
View Woodtodust's profile
Woodtodust
77 posts in 2753 days
#2 posted 10-22-2019 12:17 PM
Looks like a couple of nicks in one of the blades or nicks on two blades. dbw has the answer to correct the issue.
-- Bill...Richmond Hill, GA--"83% of all statistics are made up."
View OSU55's profile
OSU55
2658 posts in 2905 days
#3 posted 10-22-2019 12:23 PM
Can be hard to see small nicks that can cause this. Use a piece of plastic and drag the edge down the edge of the blades to feel for nicks. May have to remove the blades. Not really a big deal – plane a few more boards and you will probably have a few more scratches.
View Gene Howe's profile
Gene Howe
12263 posts in 4344 days
#4 posted 10-22-2019 01:24 PM
You can also just shift the blades so that the nicked area is covered by the next blade. If you can find the nicked one, shift that blade.
View theart's profile
theart
231 posts in 1470 days
#5 posted 10-22-2019 01:56 PM
- Gene Howe
Shifting the knives works if you’re getting a ridge, but not a scratch. If there aren’t burs on the knives or rollers, I would go looking to see of there are some splinters jammed up in there somewhere that are dragging.
View Kazooman's profile
Kazooman
1540 posts in 2868 days
#6 posted 10-22-2019 02:02 PM
I don’t think the shifting the blade trick will work in this instance. The OP indicated that the scratches are into the wood. When blades get nicked and leave a ridge you can shift one of the blades so that the nicks do not line up anymore and each blade clears the ridge that the others would leave. In this case, the planer is making a scratch into the wood. If it is a bad blade just shifting it will only shift the position of the scratch. The advice to flip the blades will be the acid test. If the scratches remain, there is another cause. I would look at the out feed roller and also check to be certain that there wasn’t something hanging down from the case that contacts the wood.
View WhyMe's profile
WhyMe
1322 posts in 2477 days
#7 posted 10-22-2019 02:08 PM
On the fist cut did the scratches start right at the leading edge of the board or do they show up into the board? Showing up into the board could be from wood resin or wood chips sticking to blade from the first cut. The second pass may have the scratches starting at the leading edge from crud build up from first cut.
Could be the depth bar has a couple of burrs and is dragging on the board.
View controlfreak's profile
controlfreak
1387 posts in 517 days
#8 posted 10-22-2019 03:13 PM
May want to feel around the depth of cut gauge because that is the only thing other than blades and rollers that I can think of that will come in contact with the wood. I haven’t really gotten under the hood of mine but if it was coming from a roller I would expect the scratch to be in a line.
CrankAddict
#9 posted 10-22-2019 03:52 PM
Thanks for the replies. I’ve been working with Dewalt support and they actually just sent me a whole new machine (pretty awesome support). The problem was very hard to pin down. It sure felt like a scratch on the walnut, but on subsequent testing with cedar it felt like ridges. There were no visible imperfections of any kind on any blades. Shifting the workpiece to the right and running it through again (same depth setting) would not remove the previous lines, it would just add new ones (which sort of rules out them being ridges you would think, but man that’s how they feel). The spacing on the lines (there were 4-5 total) were not the same as the blade screw heads so I think that rules them out. I felt a few rough “nibs” on the inside chassis right by the blade roller. I completely sanded these smooth up to 320 grit yet the problem remained. I could not see any debris on the rollers. I couldn’t feel any rough spots on the depth of cut gauge. I did not try flipping the blades around. Didn’t realize they were two sided actually. Dewalt seemed really keen on getting me a working solution with minimal effort on my end so even with me saying that I’d be willing to try more tests they just sent off a new planer. Bugs me a bit to not know what the problem really was, but again, very pleased with the way Dewalt handled this.
Kazooman
#10 posted 10-22-2019 04:07 PM
That is amazing customer service! I hope the replacement works perfectly for you. It is a great planer.
